FMIC cold side Plumbing keeps popping off!
12-15-2012, 06:25 PM | #1 |
Rep 954
Just had a boost leak about 2 weeks ago, found the source; it was the FMIC cold side plumbing omw home from about 75 mile drive (not even spirited driving) i lost a ton of boost again get home check it out and looks like the cold side coupler has popped down again. got a 1 inch longer one to hopefully illiviate this problem, anyone have any insight?
12-15-2012, 06:53 PM | #2 |
Rep 1,943
Easy Fix. Make sure the tube/hose is free of oil use a T-clamp as u can tight them more than the regular clamp.
PROCEDE, PWM Vishnu Kit, AR catless DP, BMS DCI, Helix IC, P3 gauge, 25% window tint, mattblack window trim, mattblack roof wrapped. Vorstainer CSL trunk, CF wrapped interior, 18'' Forgestar F14 Matt black, quaife LSD, M3 suspension bits, Mtech front bumper). http://www.youtube.com/watch?v=b8JIB8C8HDA
12-16-2012, 12:50 PM | #4 |
Rep 1,903
Drives: e92 335i 6MT
12-16-2012, 01:01 PM | #5 |
Rep 2,978
I had the same issue for the longest time until I found out the problem. For me, the problem was the clamp I was using. For whatever reasons, it didnt like the clamps it came with my fmic. I used this kind instead: http://www.directindustry.com/prod/i...22-574313.html, and never had the same issue.
12-16-2012, 01:32 PM | #6 |
Rep 2,396
Drives: '08 E90 335i
Check the silicone hose. Dry it & the piping it's connecting with. Then try and more intense t-clamp and tighten it down.
12-17-2012, 06:46 PM | #7 |
Rep 954
Thanks everyone im gonna get in there with a brand new longer coupler and make sure it gets over those rolled edges and dry it all out we all know oil lives in those pipes.. just dont have time to do anything these days!
12-17-2012, 08:05 PM | #8 |
Rep 2,602
Use hairspray or a little bit of silicone. Either will eliminate the problem.
12-17-2012, 11:06 PM | #9 | |
Rep 1,943
After my wedding I'm getting a 335IS if Vargas turbo upgrade stage 3 is out then but if not may be a GTR it all depends. How's ur car running?
12-18-2012, 02:04 PM | #10 |
2097
Rep 43,350
Properly seating the clamp just after the bead is crucial to preventing boost leaks. Using t-bolts vs worm gear clamps will also prevent blow offs as well as keeping the alignment of the clamp straight when tightening the clamp.
12-18-2012, 08:36 PM | #12 |
Rep 1,019
That's why I have an HPF intercooler, uses factory clamps and haven't had an issue yet. Spike 17lbs on the daily and nothing. Hope you get your issue fixed.
@ichi_ban
