n54 piston compression
12-18-2012, 02:02 PM | #3 |
Rep 7,377
Well its almost impossible to have low compression on all cylinders and if 1 is down is gonna be pretty obvious.
12-18-2012, 07:47 PM | #5 |
Rep 125
ok i did acompression test and all 6 are between 74 and 81 psi is this normal?? i knw they have to be arround 10 psi apart or less but this numbers look way to low help
12-18-2012, 08:07 PM | #6 |
Rep 105
Did you do the test dry or wet?
Vishnu PROcede 2.5SE, BMS DCI, Evolution Racewerk Charge Pipe, HKS SSQV4 |
12-18-2012, 08:25 PM | #7 |
Rep 538
That's way off. If you do the compression test correctly, comp readings should be around 165-175. To do the test right, pull all plugs out, unplug the injectors so they don't squirt fuel when you're cranking, and crank it until you head 5 'bumps' in the engine rotation. You have to push the 'Start' button to stop the engine too.
GL HTH |
