BMS Fuel upgrade test results!
01-17-2013, 02:20 PM | #1 |
Not Baned
87
Rep 1,354
01-17-2013, 03:03 PM | #2 |
Rep 579
Drives: 08 AW e92 335i
Very interesting data. I'm glad someone made an attempt to clarify the options.
01-17-2013, 03:23 PM | #3 |
Rep 216
That was some interesting test. So he mentioned that setup 4 would potentially cause stress on the electrical system and that's also how the Vishnu/FFTEC inline pump is setup, would that really be an issue?
01-17-2013, 06:58 PM | #6 |
Rep 715
Why not just run two oem pumps , for those who dont want to run E85 ?
Less amps drawn and should be able to deliver for most aplications of 335i cars at present in regards to high HP outputs.
Vargas S2 turbos|VAC S3 Cylinder head|RR DPs|RR MPs|Supersprint X pipe|Remus Quad Sport mufflers|aFe Stage 2 Si with scoops|Forge DVs|ER CP|BMS meth elbow|Aquamist HFS-4|Walbro 450 E85 LPFP|AA FMIC|BMS OCC|MHD|P3 Boost Gauge|Ohlins Road & Track + camberplates|M3 sways F/R+ Ground control endlinks|Vorsteiner v303 19"|Michelin PS2 sport|Quaife LSD|Vorsteiner V35 CF hood|CF CLS trunk|Duke Dynamics quad diffusor
01-17-2013, 07:17 PM | #7 |
Rep 1,362
01-17-2013, 09:58 PM | #10 | |
Not Baned
87
Rep 1,354
Courtesy of VargasTurboTech:
01-18-2013, 07:20 AM | #12 |
Not Baned
87
Rep 1,354
01-18-2013, 08:32 PM | #13 |
Rep 1,202
Yup, I got it all done and installed. We shall see how it works once Stage 3 is finished. Looking like next week. Fabricator has it for final weldings, brackets, etc. Then some powder coating and away we go
01-19-2013, 02:22 AM | #14 | |
Rep 2,799
thanks to MGallop |
01-19-2013, 06:31 PM | #16 |
Rep 4,499
I really like what your doing, but why not see what you can get out of it with the fuel system not modded and then use the modifications later.
Have BT Tool professional, will scan and clear codes on your BMW. And now I am able to code my 2011 335is and M4
Link to my M4 euro delivery! http://f80.bimmerpost.com/forums/sho....php?t=1006526 |
01-19-2013, 06:54 PM | #17 | |
Rep 442
