F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Cosmetic and Lighting Modifications (exterior & interior) > F30 HID foglight question
GetBMWParts
      01-20-2013, 01:00 AM   #1
Jonsiu
Jonsiu's Avatar
145
Drives: E92 328i, F30 335i
Exclamation F30 HID foglight question
Hey all, I am considering changing my halogen foglights to HID but the question remain is that I know the foglights for the F30 are also used as cornering lights so they fade in/out.. so would that be a issue if I swap it to HID? Would using HID as cornering lights be an issue for overheating or easily burnt out? Thanks!
      01-20-2013, 11:01 AM   #2
bcl0328
Drives: 2012 328i
leave them on all the time!
      01-20-2013, 03:11 PM   #3
Elk
Drives: 2012 335i
No issue; HIDs last longer than incandescent halogens. Moreover, the bulbs are not very expensive.
      01-20-2013, 05:21 PM   #4
Jonsiu
Jonsiu's Avatar
145
Alright, any good vendors with HID to recommend? Thanks!
      01-20-2013, 05:50 PM   #5
jrortiz
jrortiz's Avatar
Puerto Rico
34
Drives: 2012 328i
Someone recommend this: H8 GP Thunder 7500K 35W. I expect to buy/install them for next weekend.
Black Sapphire Metallic / Premium Package / Technology Package / Cool Weather Package / Lighting Package / Harmon Kardon surround sound system / Vossen VSF/1 Matte Graphite
      01-20-2013, 06:06 PM   #6
Jonsiu
Jonsiu's Avatar
145
I have the white halogen H8s right now, I just want to switch to a HID H8 but I am just afraid that it will easily burnt out/overheat cause it is used as cornering lights
      01-20-2013, 06:11 PM   #7
jdong
Drives: 2013 BMW ActiveHybrid 3
The fog lights are dimmed in and out when used as a turning light. That's quite a stress to the HID ballast. While HIDs do last a long time for continuous operation, they are not designed for momentary operation. They take a few seconds to warm up and stabilize at a color temperature and repeatedly power cycling them is tough on the ballast and the bulb.
      01-20-2013, 06:26 PM   #8
Elk
Drives: 2012 335i
It is a bit harder on them, certainly, and not an ideal use. However, having retrofitted HIDs into a couple of Ducatis with projector lenses, and cycling the high beam on-off a great deal without a failure, I would not hesitate to try an HID retrofit as a foglight. The ballasts and bulbs are pretty tough.
      01-20-2013, 06:26 PM   #9
jrortiz
jrortiz's Avatar
Puerto Rico
34
Drives: 2012 328i
Base on that, leaving them on all the time should be fine.
      01-20-2013, 06:27 PM   #10
Jonsiu
Jonsiu's Avatar
145
Haha yes!! This is what I am looking for!! Thanks!! You answered my "prayers"! So I guess it is not a good idea to swap the foglights to a HID then? Cause it fades in/out so often as a I make a turn?
      01-20-2013, 06:33 PM   #11
Elk
Drives: 2012 335i
If this concerns you, another option is to replace the bulbs with color temperature appropriate LEDs. As I recall someone here did just this.
      01-20-2013, 06:39 PM   #12
WonderWoman
WonderWoman's Avatar
Drives: BMW 328XI MW F3O
No there shouldn't be an issue. I have h8 6000ks on. In the beginning they may seem a little blue but once they've been on for a while they'll whiten up. I matched mine to my angel eyes ^^
      01-20-2013, 09:33 PM   #13
jdong
I'd really recommend switching to LEDs if you find that the halogens aren't your cup of tea (for whatever reason).
Out of curiosity, what is your motivation for swapping out your fogs? High-tech look? Color temperature? Inadequate light output?
      01-21-2013, 12:01 AM   #14
Jonsiu
Jonsiu's Avatar
145
I want to go 3000k for my fogs and I know halogen/LED cannot produce that pure raw yellow color without tint. But my concern is that HID will overheat/burnt out because of the constant fade in/out when steering the car.
      11-23-2013, 01:46 PM   #15
Davinaii
Drives: 2014 BMW 335i
Will that H8 GP Thunder 7500K 35W fit the F30 335 & will it cause any error?
      11-23-2013, 07:10 PM   #16
bmwluvr24
Driving Mika all over California.....
bmwluvr24's Avatar
Drives: 2008 E60 M5
I bought my HID fogs from Underground Euros, but I wouldn't recommend them anymore because I have had several error codes pop and the ballasts are terrible.
2008 E60 M5 Sepang Bronze Metallic, gloss black grills and gills, LED side markers, 12mm spacers all around, stud conversion kit, custom exhaust with Magnaflow mufflers and x-pipe.
      11-24-2013, 08:54 AM   #17
jrortiz
jrortiz's Avatar
Puerto Rico
34
Drives: 2012 328i
I install them on my 328 with out any problem. I bet they will work as fine in a 335.
Tags
foglights, hid fogs
f30post
