What makes a car a 'ringer'?
08-21-2007, 05:57 PM | #1 |
Rep 331
I've heard references to one stock 335 being significantly faster than another stock 335, but never an explanation. Personally, I was thinking that it might be the result of several key components falling within the upper threshold of their spec'd attributes...
Any ideas? |
08-21-2007, 06:00 PM | #2 |
Rep 1,441
Drives: e92 335i, f10 m5 comp
could be that... or it could be combinations of elevation, temperature, and humidity
08-21-2007, 06:00 PM | #3 |
Now With 33% MORE Sarcasm Free!
157
Rep 3,462
Simple, if a Manufacterer knows that a particular car is heading to a magazine for a day of testing many will "Tweek" said car or bike to give it that little "Oomph" that might be missing otherwise.
It's easy enough with todays software to optimize and tune a particular unit for a magazine. Extra .5lb of boost, etc... A car that is suspected of being thusly loved on by the OEM is called a "ringer".
A BMW is Just a Car, it doesn't make you smart, handsome, clever, better, cool, or wealthy. |
08-21-2007, 06:06 PM | #4 |
Rep 1,517
Drives: Ever changing fleet
Don't you have a TT?
23 iX M60, 24 GT3 RS Weissach, 22 Rivian R1T, 23 RS3, 13 E92 M3 Competition: Akra Evo, KW V3, etc
08-21-2007, 06:49 PM | #5 | |
Rep 58
"Ringers" that end up in magazines are most likely tweaked a bit by the manufacturers, but I think you're referring to regular production cars. In that case, you are correct. Even with tight quality control, there is some variation in tolerances, unavoidable in mass production. It would not be cost effective for the manufacturer to "blueprint" every single engine (unless it is an expensive limited production model with hand-built everything). As a result some cars are faster than others, as you said, by certain tolerances lining up just right. I would suspect that the range of power variation would follow some sort of bell curve. I once read that 25% of engines would be significantly below spec, 50% would be near spec, and 25% would be above, but that seems a little excessive to me, and 64% of statistics are just made up anyway. |
08-21-2007, 06:59 PM | #6 | |
AC
95
Rep 2,387
Your Supreme Leader
08-21-2007, 07:14 PM | #7 | |
Rep 331
08-21-2007, 08:38 PM | #8 | |
Rep 110
08-21-2007, 09:03 PM | #9 | |
Rep 331
Yeah, it makes sense that the manufacturer can't, in a mass production scenario, blueprint each engine. But this makes me wonder if engines produced at the beginning of each MY cycle, have a greater probability of being ringers. My theory is that at the beginning of each MY all the nifty machines responsible for assembly have been effectively 're-tooled', allowing for tighter fits, etc. Now, I don't think that this means all Bimmers produced at the tail end of a MY are going to be weaker...I'd expect various machine to be re-tooled along the way, as they wear. Of course this is all conjecture...for all I know BMW keeps chuggin along between MYs without significant reset/re-tooling. Anyone know? |
08-22-2007, 10:27 AM | #10 | |
Rep 304
The human factor likely contributes just as much as part's tolerances. Monday after a long weekend etc. Personally I wouldn't want a BMW built during or right after Octoberfest. |
08-22-2007, 11:17 AM | #11 | |
Rep 214
How about a link (or at least the title/description you used). Couldn't find it.
08-22-2007, 03:53 PM | #12 |
Too many Alex's, from now on, call me Beaufort
343
Rep 6,188
BMW made a set of ringers out of the e36 M3 and called them LTW's. Basically they tested every engine and took the ones that had the best performance and rebuilt them by hand for tighter tolerances.
There were plenty of better performing engines that were never pulled for LTW's but ended up in the regular lineup. Another reason 95's were a hot year for the M3(aside from being OBDI).
13 HD FatBob
17 A4 Glacier/Black 1st Edition/Pre+/Sport/EurocodeTMD/Racechip 16 S6 (gone),14 S6 (gone),14 S6 (gone),13 S6 (gone),10 S4 (gone) 07 335i(gone) |
08-22-2007, 04:23 PM | #13 |
BK Employee of the month! / Moderator
640
Rep 15,795
Wow, 2-3 cars? Damn... Just because you have the oil cooler? Hmmm... I want to see how my e90 goes up against a e92 with an oil cooler. I don't even have the ZSP. And since we both have the Turbo Tuner. I wonder how many car lengths you will beat me by?
Sponsored by: Pics of the ---> Barbera Beast <--- Martino Auto Concepts (Like them on Facebook MAC) Factory Trained & Authorized by BMW of North America Matt@Camber-Toe (Like them on Facebook Camber-Toe) LuxAngelEyes (Like them on Facebook LuxAngelEyes) LTBMW (Like them on Facebook LTBMW) OEMconcepts (Like them on Facebook OEMconcepts) |
08-22-2007, 05:45 PM | #14 | |||
Rep 81
Engines are "hand picked" on the power bench for CSL's and other lightweights after they are built, NOT part by part before they are built. "Ringers" are an anomoly that arises when all of the parts in the engine are exactly to spec from all those suppliers. It is a well known fact in the industry that later model years tend to have better reliability due to repetitive assembly methods. During this time, updates to parts, operation envelopes, and complaints from previous models are incorporated. Quote:
08-23-2007, 03:33 AM | #15 |
Rep 1,278
all cars produced in march or later now include a second oil cooler and redesigned fuel pump. my car felt significantly faster than a loaner 335i with similar mileage stock for stock.
08-23-2007, 01:04 PM | #18 | |
Rep 1,714
http://www.edmunds.com/insideline/do...ticleId=117669 Additional boost comes two ways: 1) Different programming (ala PROcede or "ringer" ECU) 2) Free'er flowing exhaust (see boost values with DP) I doubt there is a law against providing a non-identical press car to reviewers. But I could be wrong. |
