01-28-2013, 04:39 PM | #1 |
Dejan
1755
Rep 4,197
Drives: 2018 Audi S3
Garage List 2013 BMW 335i [10.00]
2015 BMW 228i M Spo ... [0.00] 2013 Ford Focus (DD) [0.00] 2001 Alfa Romeo 156 [0.00] |
Another F30 Rattle Fix
I posted 2 yesterday, and as I stated I would post a 3rd one after I took photos. Well here it is.
The ambient light cover is too loose on my car and it was floating around, creating like a grinding sort of sound. Well its not doing it anymore.
FBO-PS1 and stuff
01-29-2013, 10:35 AM | #2 |
Rep 160
I got this rattle or weird vibration buzzing coming from the center console when I press down the throttle to 2500-3000rpm. It is most noticeable in sport mode, however intermittent though (sometime it happens, sometimes it doesn't. You ever had this issue? You think this is the cure?
01-29-2013, 01:11 PM | #3 | |
Dejan
1755
Rep 4,197
Some of the rattle fixes I posted I already fixed months ago, but I see so many people complaining I decided to take everything apart and share what I did with you guys. Describe a little more in detail or can you pinpoint exactly where it's coming from? There is one more part I fixed in the console, but it literally involves disassembling the whole console to get to the rattle. The 2500 rpm buzz does bring back memories lol for me it was every time the car was under load the exhaust vibrated loose parts.
FBO-PS1 and stuff
01-29-2013, 03:25 PM | #4 |
Rep 160
Just took my car in today to fix the AC and the rattle. I'll let BMW deal with it and see if they can fix it. Taking the whole console out is pretty straightfoward. Pull the front trim with the fan, undo the 2 torx screw. remove the ambient cover, undo 2 torx screw.
01-29-2013, 04:56 PM | #5 | |
Dejan
1755
Rep 4,197
FBO-PS1 and stuff
02-07-2013, 01:10 AM | #6 |
Rep 23
Hi there,
this is not related to your particular rattle issue. but I have a rattle issue that comes from the front bumper. if you hit it with your hand you will hear it. you have to hit it from the lower lips upwards and you will hear a rattle inside bumper, sounds like a metal licence plate rattle sound. i posted this but no one replied to my post. I can see that you care about rattle noises. I was hopingt hat you might help me out. I was hoping that you can check your car and se if you are getting any rattle at the front bumper ? |
02-07-2013, 03:02 PM | #7 | |
Dejan
1755
Rep 4,197
Ill check mine when I get a chance. Never really thought to look, and I've had my front bumper off the car completely already didn't really find anything unusual. If you have headlight washers there is a lot of plumbing with hoses and such you may be hearing those move around. They're just clipped in nothing fancy. Not sure unless I see or hear it.
FBO-PS1 and stuff
02-07-2013, 11:54 PM | #8 |
Rep 23
Mine does not have headlight washers and I did not notice any rattling from front end unless when you go over uneven roads then everything seems to shake and the run flat tires are very hard too so that doesn't help, but anyways thats a different story.
Im sure it rattles while driving cause you don't have to tap it hard to hear it. I am tapping on the lower lips each side doesn't matter which side it sounds the same. but if i hold the middle area where licence plate area is while tapping/hitting the lower lip then sound goes away and sounds pretty solid.... so sounds like something is loose inside ? It doesnt really sound plastic rattle. it sound like metal. like a licence plate rattling on an old car. i thought it was coming from the chrome accents. I have two chrome lines (luxury line) but when i hold those and hit nothing changes. so those are not the issue... you said you took ur bumper off. So is there any clips or screws etc that hold the middle section of the bumper cover inplace? keeping it attached to the metal bar/bumper behind it? cause my bumper had a small scratch and bmw dealer repaired it. I am not sure if they took of the whole bumper and forgot to attach some clips ? |
02-08-2013, 08:05 AM | #9 | |
Dejan
1755
Rep 4,197
Maybe the delaer didnt secure something. Definitely sounds like something is loose. Not sure if this helps but if you venture out on your own in taking it off here is the link for the DIY; http://www.f30post.com/forums/showthread.php?t=707251
FBO-PS1 and stuff
02-08-2013, 08:22 PM | #10 |
Rep 23
thank you for the DIY. gives me an idea of whats in there. But i don't have the tools, and the garage space to work on it myself. Sadly I might have to take it to dealr again, but that pisses me off cause everytime I take it in there they either scratch something or manage to mess up another thing.
02-09-2013, 06:49 AM | #11 | |
Dejan
1755
Rep 4,197
I hope you figure out what it is. It may be a bracket they forgot to tighten all the way that holds on your bumper. Ive seen stupid little things like that before. Good luck.
FBO-PS1 and stuff
02-09-2013, 06:51 AM | #12 | |
Dejan
1755
Rep 4,197
FBO-PS1 and stuff
02-12-2013, 05:33 PM | #13 |
Rep 160
They mention it might be the exhaust pipe rattle the heat shields. they adjusted the heat shields. Didn't do anything though; rattle still there. I still believe it's just something touching in the center console. (maybe the CIC with the center console panel? front fan trim? I'm just gonna take it apart one day and foam tape everything. Probably gonna do the ambient cover too. They did put a 1 inch deep scratch (through paint, can see primer) my fender though. They're gonna fix it though since I spotted it before I drive off. *sigh.
02-13-2013, 02:41 PM | #14 |
Rep 120
Great job! Thank you, I hate rattles in my car and one was coming exactly from this panel.
Honda Accord -> Subaru STi -> E93 -> F30 + F15 -> F30 -> F31 LCI -> G31
02-15-2013, 08:02 AM | #16 | ||
Dejan
1755
Rep 4,197
Thanks I like to help out when I can.
FBO-PS1 and stuff
02-16-2013, 09:26 PM | #17 |
Rep 139
04-24-2013, 08:57 AM | #19 | |
Rep 52
Plastic noice
I was wondering have you find any more locations where you had to put foam type. Thank you. |
09-17-2013, 01:25 AM | #20 |
Rep 67
I am having the same issue with my 2013 335i M Sport. I do have a trim removal set that I never opened :-) I will look into this. Thanks so much for the DIY!
I will confirm if this works for me.
2016 F85 X5M - Black on Black, loaded
2016 F80 M3 - Black on Black, 437M Black wheels, Black kidney grills - SOLD 2013 F30 335i - M Sport, MPPK, MPE, DinanTronics Stage 2, Dinan Suspension - SOLD 2007 E90 335i - Dinan Stage 2, BMW PE - SOLD 2002 E46 M3 Coupe - CSL wheels - SOLD |
09-18-2013, 08:16 AM | #21 |
Dejan
1755
Rep 4,197
It should work real well. Thus was one of the easiest rattles i have fixed to date. I have had a few f30 loaners, so far they all did it. That panel is just too loose IMO.
FBO-PS1 and stuff
09-18-2013, 02:12 PM | #22 | |
Rep 139
everytime I fixed one, theres another one that appears. Any other ones you have fixed? Tks! |
