Track build thread?
02-03-2013, 03:25 PM | #1 |
Rep 739
Track build thread?
I have a 2007 e92 335i.
current mods are: JB4 G5 iso w/ COBB backend flash 100% e85 map 5 Dual cone intake BMS oil catch can VRSF downpipes VRSF intercooler Straight piped exhaust but with added vibrant resonators M3 front suspension conversion bits VMR 18x8.5 18x9.5 Toyo R888 255 285 zimmerman rotors porsche super blue fluid EBC red stuff Motul power racing 300v 5w30 Water Wetter Front alumalite splitter m3 front bumper some weight reduction car weighs 3400lbs without me in with a 1/2 tank of gas Im in the market for: Limited slip diff - -Which one do you guys suggest? Coilovers - Im looking for soemthing that i can get for around 2k with camber plates Right now the car is pretty great i never have problems over heating and the grip is incredible with the r888's does anyone have any suggestions on any mods i should do? |
02-03-2013, 05:48 PM | #2 | |
Rep 1,052
It'll do a lot more for you than a limited slip although that is a great upgrade. |
02-03-2013, 05:53 PM | #3 |
driver mod in progress
225
Rep 1,858
Drives: with both feet
I'm in the market for a LSD too. I know TurboMike has a Wavetrac. You could PM him what he thinks about it. If you do, post his response as I'm curious too.
As for coil overs, I love my KW V1s even though they don't have camber plates. You could always pick up a set of Vorshlag CPs, though. I think they run in the $200-300 price range. Glad to see you haven't had any issues with limp mode or over-heating even though you just have the OEM oil cooler. I'm on the fence about whether or not I should pick one up before I go to the track or just wait and see. My oil temps were up over 250F this morning cruising on Angeles Crest (highway 2) and it was 40 degrees up there. I'd imagine any track in the desert would put me into limp mode. Any videos of you tracking? Nice car any pics?
02-04-2013, 11:16 PM | #4 |
Halle Berry or Hallelujah
Rep 57
Lets see I'd go for the ohlins road and track coilovers with custom swift springs and the vorshlag camber plates. Quaife LSD and it is essential that you get it corner balanced and aligned by someone who knows what the hell they are doing. I've decided the shop I would go to when I get my LSD is HP Autowerks in Santa Barbara. Best alignment shop I've ever been to and the ONLY place I will ever get my car aligned is West End Alignment in Gardena. If you really don't know what you want I'd suggest calling HP Autowerks and talking with Harold.
02-04-2013, 11:36 PM | #5 | |
Rep 739
thanks i just need to find a good place in florida to do an alignment.. |
02-05-2013, 06:47 AM | #6 |
Rep 12,570
Drives: Z4 M, X5, GX460
Garage List F15 X5 xDrive35i [8.75]
E86 Z4 M [10.00] F10 550i (Retired) [9.17] F25 X3 xDrive35i (R ... [9.43] E82 135is (Retired) [9.50] E85 Z4 M (Retired) [9.41] E90 328i xDrive (Re ... [9.25] E86 Z4 3.0si (Retired) [9.08] |
I'm surprised you are tracking with vmr's and ebc red. Those wheels are ridiculously heavy and those pads are really meant for street use.
While ohlins are ideal not sure how streetable those are assuming you're not trailoring this car. If this car is still your daily I'd look for something more street friendly, ie kw clubsports which come with camber plates. Last edited by 3002 tii; 02-05-2013 at 06:53 AM.. |
02-05-2013, 01:41 PM | #7 |
Rep 57
The ohlins are called ROAD & track coilovers. So I'm pretty sure they'll be more than adequate on the street. "This balanced suspension package provides racetrack performance with street comfort" <-- taken from ohlinsusa site.
As for where to get your alignment and corner balance in Florida. I'd ask Improved Racing (http://www.improvedracing.com/contact_us.php) I bought the owners slightly used ohlins pcv with custom swift springs for my RX7. He's a ohlins distributor and an engineer. Should know whats up in Florida. |
02-05-2013, 01:47 PM | #8 |
Rep 57
02-05-2013, 02:55 PM | #9 |
Rep 12,570
I agree but eventually you will and you'll need to upgrade pads before you touch the suspension
02-05-2013, 05:40 PM | #11 |
Rep 1,052
Just a note: brakes, tires, and suspension are all part of a system that needs to be matched. Too much pad for tires=bad. Too much tire for suspension=not great. Not enough suspension for tires=not great.
There's more but with the Ohlin Street/Track, which are great on the street BTW, an R-comp with race pads or extreme summer tire with something like PFC Z-Rated would be great. There's a lot more detail but this "Balanced System" concept is important in developing your car. Just IMHO |
02-06-2013, 08:29 AM | #12 |
Rep 638
You got a lot of power and r comps. If Red stuff doesn't workout for you, let me advise you to save some money and troubles of trying other useless pads, and go straight to PFC01.
02-06-2013, 05:41 PM | #13 | |||
Rep 739
the vmr wheels had good offsets for the size tire i wanted to run 255/285 but i think im going to make the switch to apex ec7 18x9 front 265 and 18x10.5 305 rear Quote:
but i will look into the pfc01 Also whats the best mod you have done for your car for the track? Im expecting suspension brakes tires driving school etc.. but i would like to hear some small things that you have done that surprised you |
02-06-2013, 05:45 PM | #14 | |
Rep 1,973
Drives: 2009 e92 MR "Civic" ///M3
The PFC01's are great pads, great torque, easy to modulate. But they will wear out quick(ly). The PFC08 is the endurance version similar to the Pagid Yellow RS29, it's hard to go wrong with either of those two.
|| DCT | ESS Tune | ACM Test-pipes | AA Green Filter | Swift Spec-R Springs | Stoptech ST-40 F || || My Youtube Channel ||
02-06-2013, 09:20 PM | #17 | |
Rep 739
Does anyone have suggestions for wheels that are light and come in 18x9 et30ish and 18x10-11 et40 ish i don't use separate wheels for track and dd so i would just like 1 set of wide wheels |
02-06-2013, 10:27 PM | #18 | |
Rep 1,052
02-07-2013, 12:45 AM | #19 |
Rep 739
yeah i looked at apex as they have a 9 front 10 rear setup that would work but i think i could go 10.5 in the back pretty easily...
02-07-2013, 01:33 PM | #20 |
Wannabe Track Rat
70
Rep 930
The more you stagger the setup the more the car will push in the turns. You can dial up the firmness all you want in the rear and soften the front, but with a big stagger the car will push and eat front rubber.
2017 OG M2
02-07-2013, 09:35 PM | #21 |
Rep 739
currently my car is neutral if i throttle through a turn it will oversteer if i let off in a turn it will understeer 255 285 i think it wil be ok doing 265 295 or 305 and it will probably be faster due to the fact that in general i will have more traction and be able to exit turns faster
02-08-2013, 11:41 AM | #22 | |
Midlife Crises Racing Silent but Deadly Class
1821
Rep 5,337
Drives: 2006 MZ4C, 2021 Tesla Model 3
Here comes some worthless opinion on my part. A build requires IDENTIFYING what is the weak point of a chassis and fixing and addressing those weak point accordingly. Throwing parts at it willy-nilly may actually exacerbate the weak point of the chassis. In my opinion, the E9X chassis is so advanced that 90% of the issues can be resolved without touching the chassis. The BIGGEST weak point of the E9X, and 335i by extension, is the COOLING SYSTEM. If you can't address that first, fixing everything else is meaningless. By making the chassis faster, you're only exacerbating the cooling issues inherent in multiple part of the chassis. So any talk of a build without 1) upgrading cooling for the engine and 2) upgrading cooling for the brakes and 3) upgrading heat capacity of the tires will ultimately result in a car that will be LESS drivable compared to stock. Frankly, if what you're saying is true, that you have not had any cooling issues at track (unless, of course, it's a straight track you're talking about, i.e. 1/4 mile), then the problem with your chassis, and the BIGGEST weak point of the car, is with the DRIVER. Again. IMO. If you don't fix those weak points first, "building" out the chassis is meaningless.
Sitting on a beat-up office chair in front of a 5 year old computer in a basement floor, sipping on stale coffee watching a bunch of meaningless numbers scrolling aimlessly on a dimly lit 19” monitor.
