help!pwm cant work.
02-18-2013, 03:16 AM | #1 |
Rep 283
help!pwm cant work.
hey guys
my pwm kit has some error,I carefully check each connector. when I check the flow Nozzle,its cant open! I know its Hall-effect sensors,but its dont work. any advise thanks! |
02-18-2013, 04:55 PM | #3 | |
1750
Rep 17,960
Drives: A Lot
I'm not sure I follow. The pic you posted is of the FAV (fast acting valve). The hall effects sensor is something completely different and is a part of the flow sensor. When you apply 12v and Ground to the two parallel blade terminals on the FAV connector, do you hear a click? Shiv |
02-18-2013, 06:12 PM | #4 | |
Rep 283
I m very glad to see your reply because means vishnu new works published Yes I hear the sound from the relay But it can not be opened. In front of it, everything is normal. |
02-20-2013, 01:44 AM | #5 | |
Rep 283
I carefully checked each wire. I remove the solenoid valve to try to use a 12v circuit connection He is normal, and can be turned on or off. I also measured the electromagnetic valve - relay-procede |
02-20-2013, 01:36 PM | #6 |
Rep 497
Bypass the resistor. Attempt a direct 12v connection. Remember these are Positive +opening valves. I thought mine was bad as well. Until I applied a direct 12v current and it actuated correctly.
It took me some time to figure if it worked. Took me back to the ecu and then I determined how this was engineered. Think about what line was tapped off the harness. I hafta say tho Shiv, the bench test your guys provided wasn't correct.
08' 335xi 6MT Space Metallic Grey Premium, Nav, Cold weather, Sport Procede 2.5, DCI, Forge DV, PWM, Scoops, KW V1, ETS 5" FMIC, VRSF Downpipes, M3 Skirts |
02-20-2013, 01:39 PM | #7 |
Rep 497
Also if I'm not mistaken that entire valve can be disassembled, iirc. I took one of them completely apart.
02-21-2013, 03:58 AM | #8 | |
Rep 283
I've tried to solenoid valve separation, to give him a 12v power supply and grounding line, I noticed that in fact the grounding line should be connected to procede. As long as I connect it to procede, it can not open properly, has a magnetic. If you give it a separate grounding line, it can work. I do not know what I can do. |
02-21-2013, 04:11 AM | #10 | |
Rep 283
But to procede the grounding line does not work. I found a piece of magnet, put it on top, the valve is open state, I want to use control tank line to control valve. |
