Help
03-22-2013, 07:04 PM | #1 |
Rep 39
Help
I have spent the last 2 hours searching for answers only to be more confused. I was driving this evening and went to pass a car and hit limp mode ses light half engine light no power. I pulled over restarted car still the same would not even rev up. Reset ses light will crank up and run but shakes badly and sounds like a diesel running. The SES light keeps flashing. Getting the following codes.
12474--30BA 10700--29CC 10701--29CD 10702--29CE 10703--29CF Thanks for your input!!! |
03-29-2013, 01:09 PM | #3 |
Rep 39
Update
In order of repairs
3 injectors--still running badly could not clear SES light replaced DME replaced all 6 coil packs Now running as it should!!! |
03-29-2013, 01:39 PM | #4 |
Rep 2,626
you probably should have started with the easy stuff like coils
'18 F80 M3 Comp 6MT - Stock
'07 E92 335i 6MT- HP650, inlets/outlets, ER FMIC, VRSF CP, LPFP stg2, CSF rad, 'is Aux rad, ER OC, Ohlins, M control arms, eibach front sway bar. '05 C55 AMG SOLD - '22 Tesla M3P | '10 E92 335i M, 6MT | '07 E90 335i, PTF COBB E50, FBO, HFS4 |
03-29-2013, 01:39 PM | #5 |
Rep 2,626
but anyway, glad you got it sorted out
03-29-2013, 05:25 PM | #6 |
Rep 129
The giveaway is the 30BA code - it means a MOSFET in your DME failed - I got the same codes as you and same symptoms. You can get a new MOSFET for $2 and have a computer or tv repair place solder it back on for you for $30 or so.
I just had this happen to me 3 weeks ago. Just google 335i DME died and you'll see lots about it and a DIY by a guy called Roy Cromier I think that explains it - that's how I fixed mine. |
03-29-2013, 05:54 PM | #7 |
Rep 2,626
^ Oh yeah, missed that code.
04-01-2013, 07:40 AM | #9 |
Rep 129
With all due respect, replacement is not the same as repair. Happy you got it solved - just keep it in mind if it happens again in future or for anyone else that is out of warranty and reading this.
