gear oil smell?
03-23-2013, 05:20 PM | #1 |
DIYER
614
Rep 5,521
gear oil smell?
I get a smell after going WOT or aggressive on the gas and it smells just like fear oil. Reason this concerns me I'd I have a wavetrac installed in the pumpkin and the seals where slightly leaking, took it back and got this resolved and there is no evidence of leaks anywhere. Only thing I can think of is the differential cover is slightly leaking at the top somewhere and no fluid is leaking...just the smell. I used the "right stuff" gasket maker and it has always worked great in the past.
Edit: I did use JB weld to seal a weld that had a bit of water draining out near the mid pipes. I can't see JB weld making a smell once cured....exhaust is not that hot that far down. Any ideas?
JB4 G5, Stage 3 LPFP, Stage 2 MOTIV PI, VM 6466 ST, Custom OCC W/ SS lines, ER FMIC, ER CP W/HKS BOV, M3 control arms, M3 guide rods, M3 upper links, M3 front & rear sway-bars, HPA rear toe arms, Wavetrac LSD, HPF Gen 2, DEFIV kit, KW clubsport, Delrin solid SF bushings, stoptech rotors, Rogue Tranny Mounts, 1M bumper, M3 CF hood, M3 fenders, M3 OEM sideskirts, Mtech rear bumper, CSL trunk, MORR VS8.2 rims 245/295
03-24-2013, 11:09 AM | #2 |
Rep 1,950
Drives: 335i
before my transmission checked out, after driving it hard i would always smell transmission oil. not sure if it smells like the "right stuff" but it smells bad and more of a hydraulic fluid smell. when i pulled the transmission i noticed there was an overflow valve on top of the trans, and it had oil residue around it, i figured the smell came from there. but i know for a fact i never overfilled my trans. if you know what the ZF 6 fluid smells like you might be able to relate. good luck and i hope its nothing close to your trans god forbid.
03-24-2013, 12:32 PM | #3 | |
DIYER
614
Rep 5,521
03-24-2013, 07:04 PM | #5 |
DIYER
614
Rep 5,521
slightly, more outside the car and in trunk...passenger side is worst...I think maybe brakes. I also replaced a filter under the fender liner a week ago. Snell goes away in 2-3 mins.
