Couple Of Newbee Questions... (Brakes & Weird Noise)
03-24-2013, 09:42 AM | #1 |
Safety Car Driver
13
Rep 369
Drives: E92 330D & E92 M3
Hi,
I was wondering if someone could first help me on the number of brake pad sensors on a E92 330D.. Are there only 2, one on one side at the front, and one on one side at the rear? I did try the search feature, but being somewhat of a forum slowmo, i couldn't find what I was looking for. Also, I have discovered a faint rubbing/grinding drone, that seems to get louder as the car gets quicker! Its not brake related I don't think, possibly a wheel bearing.. Anyone had anything similar or are the 330d's renowned for failing bearings/hubs after 80k? Advise much appreciated..! Thanks |
03-24-2013, 01:47 PM | #3 |
Rep 3,201
Drives: E92 325i MSport Coupe
James the noise is very likely the o/s/r brake sensor. Remove the wheel, pull out the brake sensor, lightly sand the area of the sensor that contacts with the disc and apply a thin coat of copper grease to the rest of the sensor. Re-insert the sensor in the caliper and enjoy peace and quiet!
E92 pre-LCI 325i - Ohlins R&T; H&R spacers; M3 strut brace; Swift thrust sheets; 3 x chassis braces; diff brace; N53 V-brace; 034 subframe inserts; BMS clutch stop; BMS CDV; RE g/box mounts; Delrin shift bushes; Saikoumichi OCC; Cyba scoops; BMW Perf Exhaust; HEL s/steel brake hoses; M3 rear spoiler; Recaro Sportster CSs; M3 white dash LEDs; LED Angels; LED side repeaters; BMW Perf black grille; CSL reps; SSDD carbon diffuser; Monster Wrap black roof/clear front
03-24-2013, 02:17 PM | #4 |
Safety Car Driver
13
Rep 369
Jedimindtrix - Thanks, So I only need to order one when doing the front pads!
Phil - thank you for that, I shall try that this week and see how I get on and hope that it cures it!! |
03-25-2013, 10:10 AM | #5 |
Safety Car Driver
13
Rep 369
Stupid question... I am struggling with getting the right part number for my car for some yellowstuff pads, can anyone help? 2007 E92 330D.
Thank You |
