E90Post
Coby Wheel
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > out-put tranny play
Reply
      03-24-2013, 01:39 PM   #1
robc1976
DIYER
robc1976's Avatar
614
Drives: E90 335i
out-put tranny play
Wondering for those of you who ever messed/removed your driveshaft (I have done it 5 times note lol!). I am wondering if anyone knows or took note how much play was in the out-put shaft of the tranny?
JB4 G5, Stage 3 LPFP, Stage 2 MOTIV PI, VM 6466 ST, Custom OCC W/ SS lines, ER FMIC, ER CP W/HKS BOV, M3 control arms, M3 guide rods, M3 upper links, M3 front & rear sway-bars, HPA rear toe arms, Wavetrac LSD, HPF Gen 2, DEFIV kit, KW clubsport, Delrin solid SF bushings, stoptech rotors, Rogue Tranny Mounts, 1M bumper, M3 CF hood, M3 fenders, M3 OEM sideskirts, Mtech rear bumper, CSL trunk, MORR VS8.2 rims 245/295
      03-24-2013, 04:08 PM   #2
Dave W.
Drives: Porsche 951, 1992 Eagle Talon
There should be no freeplay in the trans output shaft/flange. It should rotate a little, but no side to side or up/down play. Did you find an oil leak in that area? I saw your 'oil smell' thread, maybe the oil is getting sprayed on the exhaust pipes right behind the trans and it only gets hot enough to burn after a full pull.
      03-24-2013, 04:23 PM   #3
robc1976
DIYER
robc1976's Avatar
614
Drives: E90 335i
Yeah, that is the play I was referring to (it rotates a bit and I can spin the drive shaft a bit) there is no trace if oil anywhere...differential is bone dry, tranny area is bone dry & exhaust is bone dry. I am thinking it is brakes our stuck caliper because the smell was more notable on the passenger side...goes away pretty fast Like the brakes get hot then cool down. I did have the brake light come on a few days ago and reset it like usual lol!
      03-24-2013, 05:45 PM   #4
sammy_0559
sammy_0559's Avatar
Drives: 335i
2008 E93 335i  [3.66]
im gonna check the play in the transmission I'm installing hopefully this week hopefully my professors don't rape me with another exam, school and work have been getting in the way of me installing my trans. anyway see that blue looking cap on the top of both transmissions. my blown one on the ground has oil around it. when i would drive my car hard i would get a smell, the smell was weird did not know where it was coming from lol jacked up the car check the transmission and it was dry! ha but when i dropped the trans i was like "aha" fucker that where the smell was coming from. same smell occurred on my last pull
      03-24-2013, 06:47 PM   #5
robc1976
DIYER
robc1976's Avatar
614
Drives: E90 335i
man that sucks, can you measure the rotational play in the output shaft/quibo? How bad wad removal...how heavy is it? Doesn't look to be that heavy, with my differential I didn't even use a Jack...I held it in place...my wife screwed in bolts LOL!
      03-24-2013, 06:53 PM   #6
sammy_0559
sammy_0559's Avatar
Drives: 335i
maybe 100lbs haha i carried it like a cripple but i carried it!! pulled it out like any other transmission, there is an access hole for the tourqe converter bolts rotate the engine to other bolts, then all the bolts on the bell housing i removed downpipes as well. and had my exhaust and diff dropped just cuz LOL. used long extensions to remove the bell housing bolts, i wanna make a DIY but i was in such a rush to remove it i didn't take pictures..
took me 45 minutes after i got everything out of the way. pushed up the pulled back and it pulled right out.
i don't know if measuring the play when the trans is out is gonna be accurate because the tourq converter is out of it and its not connected to the engine. but if you want ill send you a video of the play in park. witht the transmission out of the car
      03-24-2013, 07:01 PM   #7
robc1976
DIYER
robc1976's Avatar
614
Drives: E90 335i
do a install vid! U would like a video of play if you can man...very much appreciate this!
      03-24-2013, 07:05 PM   #8
sammy_0559
sammy_0559's Avatar
Drives: 335i
i will try!! the earliest i can get to it is end of this week, i shall update you with progress/ videos. when i can.
      03-24-2013, 07:08 PM   #9
robc1976
DIYER
robc1976's Avatar
614
Drives: E90 335i
that would be awesome...you have a Bentley manual? If not key nee know I'd you need any torque specs.
      03-24-2013, 07:30 PM   #10
sammy_0559
sammy_0559's Avatar
Drives: 335i
will do, i got access to all data they usually got tourqe specs but hopefully i don't fuckup the tourqe converter install it i do the oil pump is toast when i start it! LOL
      03-25-2013, 06:58 PM   #11
Tzu
Drives: 335i
HPF has a great clutch install video, shows all the steps necessary for trans removal. It isn't that hard but I wouldn't do it on my back.
      04-05-2013, 01:05 AM   #12
sammy_0559
sammy_0559's Avatar
Drives: 335i
here are your videos as promised
      04-05-2013, 07:57 AM   #13
robc1976
DIYER
robc1976's Avatar
614
Drives: E90 335i
sweet! Exactly what I needed!
Reply
e90post
