ATF - Can I use this as a replacement to OEM?
03-26-2013, 01:58 PM | #1 |
DIYER
614
Rep 5,521
I've never liked OEM BMW oil and I don't honestly think that their ATF is necessarily automatically better than any/all alternatives.
I found this and it claims it's compatible with my vehicle...I was going to use Redline but I'd like to do this today and Redline isn't available locally. Judging by reviews, it appears to be a really good product but I'd like some of your opinions. http://shop.advanceautoparts.com/web...d=1#fragment-1 Here's the specs from Castrol on this and it's saying it's BMW compatible with LA2634, LT71141; Texaco ETL-7045-E, ETL-8027B, Shell M1375.4 - as OEM is. http://www.castrol.com/liveassets/bp...s_ImportMV.pdf
JB4 G5, Stage 3 LPFP, Stage 2 MOTIV PI, VM 6466 ST, Custom OCC W/ SS lines, ER FMIC, ER CP W/HKS BOV, M3 control arms, M3 guide rods, M3 upper links, M3 front & rear sway-bars, HPA rear toe arms, Wavetrac LSD, HPF Gen 2, DEFIV kit, KW clubsport, Delrin solid SF bushings, stoptech rotors, Rogue Tranny Mounts, 1M bumper, M3 CF hood, M3 fenders, M3 OEM sideskirts, Mtech rear bumper, CSL trunk, MORR VS8.2 rims 245/295
03-26-2013, 02:22 PM | #2 |
Rep 7,377
The castrol should be fine. I use redline d6
03-26-2013, 02:28 PM | #3 |
Rep 1,950
Drives: 335i
Whats the difference between d4 and d6?
is it better than OEM in general..lol I'm about to put my transmission back together and just bought a shit ton of oem fluid. did not want to use anything below the original lol if its better i might sell it and get redline.. |
03-26-2013, 02:33 PM | #4 | |
DIYER
614
Rep 5,521
03-26-2013, 03:15 PM | #5 |
3442
Rep 79,211
If you want to wait, I can get you Red line stuff. I just need a part number. Huge inventory in stock and ships same day if ordered before 6PM ESTD.
03-26-2013, 03:16 PM | #6 |
DIYER
614
Rep 5,521
They also have a "max ATF" by royal purple. Wich is better? I have heard good things about royal purple but still would like another opinion.
03-26-2013, 03:18 PM | #7 |
DIYER
614
Rep 5,521
I appreciate that Jeff but really need to do it today....pan is dropped lol!
03-26-2013, 03:21 PM | #8 | ||
3442
Rep 79,211
Most people find that experiences on different platforms yielded more attractive or less attractive results. I.E. Redline smoothed shifting, or XX made it feel more notchy, ETC Without many people changing their fluids frequently on this platform, you need to roll the dice on any aftermarket option. Red Line, Motul, Royal Purple, Mobil 1, and Amsoil are all reputable in their own right. I would personally use OEM on this car if you dont want any surprises, however, any of the above mentioned should be just as good so as long as they match the ratings required from BMW. |
03-26-2013, 03:35 PM | #9 |
Rep 7,377
redline d6 has much higher flash point so should take more heat without degradation
