Procede v2 User Adjustable features
09-05-2007, 12:29 PM | #1 |
1750
Rep 17,960
Drives: A Lot
Hi guys,
As mentioned earlier, here are screen shots of the beta v2 software (inaccurately named v1.02 for now). It offers the following user-tunable features: -User adjustable valet RPM switch -User definable boost/torque curve The RPM switch dictates the engine speed, that must be reached within 2 seconds of engine start-up, to active the performance map. Unless this engine speed is reached (through a simple throttle blip), the PROcede will induce a stock map. This feature can effectively be removed by setting the RPM switch to 0RPM. The user definable boost/torque curve allows the user to dictate the shape of their torque curve based upon their preference. 100% in all the cells represents a full tilt boogie tune (great for drag racing on race gas, for instance). While numbers in the 85-95% induce a safe and strong pump gas map for daily driving. This table will already be configured by us. We'll be releasing more user adjustable parameters as time goes on, and as necessary for other upgrades (downpipes, intercoolers, etc,.) Cheers, Shiv Last edited by OpenFlash; 09-05-2007 at 01:18 PM.. |
09-05-2007, 12:34 PM | #3 | |
1750
Rep 17,960
Drives: A Lot
shiv |
09-05-2007, 12:34 PM | #4 |
Rep 1,137
09-05-2007, 12:34 PM | #5 | |
Rep 617
09-05-2007, 12:35 PM | #6 |
Rep 10,587
very cool shiv. Now the bluetooth connection would be a huge bonus so I can change my tq curve that much easier.
Are you saying running 100% across the board wont work on pump gas....say 93 octane? Have you run any dyno's that you can post for us showing the difference between the percentages?? Did I make the first batch of V2 harnesses?? ok ill stop
09-05-2007, 12:39 PM | #7 | |
Rep 1,938
looks pretty good. so let me ask you this, if you make all RPM points at 100% and run 91octane in 115f heat? Is there a good chance of blowing the engine or will the failsafes come into play before that point? |
09-05-2007, 12:43 PM | #8 | |
Rep 10,587
can we type in 200% and get double the power.........maybe even 500%
09-05-2007, 12:44 PM | #9 |
Rep 1,432
100% in all torque waypoints is gonna be neck snapping for daily drive. Whats the default setting on the V2 map ? Its not 100% for all rpm ranges right? Does the valet feature come enabled/disabled by default?
Cheers and Thanks! |
09-05-2007, 12:45 PM | #10 | |
Rep 10,587
Just get used to blipping the throttle at start up, no biggie.
09-05-2007, 12:46 PM | #11 | |
Rep 1,137
Should we just input specific percentage values for 91, 93 and 100 oct respectively? |
09-05-2007, 12:48 PM | #12 |
1750
Rep 17,960
Drives: A Lot
I run my car at 100% everywhere. On 91oct. In the middle of summer. Then again, it's our test car and probably sees more stress than any other car on the road. We will set the default settings to deliver strong power right out of the box. But we will leave some adjustment range for those who want to run high octane fuel and extract more power.
Shiv Last edited by OpenFlash; 09-05-2007 at 01:04 PM.. |
09-05-2007, 12:51 PM | #13 |
Rep 384
09-05-2007, 12:56 PM | #14 |
Rep 617
09-05-2007, 12:57 PM | #15 |
Rep 1,137
09-05-2007, 01:00 PM | #16 |
Rep 1,760
i wish the gear dependant option was already there, i would love to limit torque in first andf have 100% in the rest, i always floor it, keep traction with v1 barely v2 ill have to actually pay attention
09-05-2007, 01:05 PM | #17 |
Shadow Warrior
143
Rep 2,095
While I understand the concept I can't visualize where you'd want to limit certain boost and why unless it's uniform throughout. Or perhaps certain RPMs would make sense being lower than 100% while others stayed at 100%. Someone got any practical examples to help explain it better?
Also, could someone potentially fubar things up if they customized the ranges to jump back and forth from a low %age to a high %age repeatedly? Might not be much sense in it, but speaking from an idiot-proof perspective, I'm just curious.
335i E90 / Arctic / Gray / Burl Walnut / Steptronic / ZPP / ZSP / Paddles / CA / Nav / PDC / OEM Spoiler
Mods: PIAA Angel Eyes, Rear Fog Switch, Escort X50 Blue hardwire, 30% Charcoal Llumar Installing soon: Rear Power Outlets (Happy Robot mod!) |
09-05-2007, 01:06 PM | #18 |
Rep 4,481
User defined settings are the way to go. Find the right hardware - software configuration and you'll get the most reliable and powerful tune possible.
Compliments ! Eugen |
09-05-2007, 01:14 PM | #19 | |
Rep 1,760
or for those that dont like that dropping off of torque feeling, limiting the earlier RPMs so its flat and yea, im going to bet goin 100, 50, 100, 50, 100 at each 500 rpms would piss the wastegates off pretty hardcore |
09-05-2007, 01:14 PM | #20 |
Modder Raider
760
Rep 8,633
Drives: M3
Charlie, do you have a custom tune with the procede for your downpipes?
e36 M3 Coupe, e36 325i Sedan
e90 335i--SOLD Best 60-130-------------9.15 Seconds------------------WWW.MR5RACING.COM |
09-05-2007, 01:21 PM | #21 |
Rep 1,137
It is nice that the next steps are planned and they go to the right direction - towards more power.
Bear with me. I'm a simple guy. What features do I need? 1. More power (40whp) 2. More power to the ground (speed/gear dependent boost) 3. More power (Map or custom tune possibility for IC + TB + Intake+higher octanes) Generally, the low power version (=dark) could cover the power decrease stuff, wheres V2 could cover the power increase stuff for us simple people who always abuse their car to the fullest =100% and beyond, if possible. |
