AR Catless downpipe vs BMS catless Downpipe on 335i Xdrive coupe
03-26-2013, 07:32 PM | #1 |
Rep 62
Hello, I am wondering why there is such a big price difference in the catless downpipe from BMS and AR Design? The AR downpipe is $1000 and the BMS downpipe is $600.
Thanks for your time! |
03-26-2013, 08:34 PM | #2 | |
Rep 1,314
Drives: 2021 X3 M40i, 2018 Mustang GT
PM Mike@n54tuning for best prices. I got mine from him. |
03-26-2013, 08:35 PM | #3 |
Rep 4,393
Also I could be wrong but I don't think BMS makes xi downpipes yet...
< Click picture for photoshoot
E90 335i xDrive 6spd, Nav, Prem, Cold Weather, & Sports package - Msport Conversion Mods: JB4 + MHD, Doc Race ST, Pure 6266, AD-Eng PI/Mounts, Fuel-It st. 3, Custom Exhaust, Tuned by TwistedTuning More Pictures: Build Thread /// 683AWHP/675AWTQ |
03-26-2013, 08:42 PM | #4 |
Rep 497
VRSF FTW
08' 335xi 6MT Space Metallic Grey Premium, Nav, Cold weather, Sport Procede 2.5, DCI, Forge DV, PWM, Scoops, KW V1, ETS 5" FMIC, VRSF Downpipes, M3 Skirts |
03-26-2013, 09:38 PM | #6 |
Rep 2,663
Drives: BMW 335xi Sedan; BMW M3 ZCP
I paid $780 for y AR design 1 year ago. XI here
335xi Sedan 6AT | Weather(70-85°F) | N54 Tune Comparison Chart || N54 Turbo Upgrade Comparison Chart
-PROcede Rev. 2.5 ~ v5 (3/17 maps) / JB4 (8/21 maps) / COBB (Stg2+FMIC LT Aggressive maps) †Procede Map2(UT 45 - IGN 40) Aggression Target 2.0 | 0-60 in 4.0sec || †Cobb E30 LT (35% Ethanol/65% 93 Octane) | 0-60 in 3.9sec AR Design Catless DP | BMS DCI + OCC | ETS 5 FMIC | Alpina B3 Trans Flash |235/265 19" Michelin PSS |
03-27-2013, 10:03 AM | #9 | |
Rep 644
BSM 2008 135i
-VRSF 7" IC -VRSF DP's -n55 mids -BERK race -ER CP -TIAL BOV -BMS DCI -JB4 G5 ISO -ST coils -STOPTECH slotted rotors & pads -SLeK lip Follow me on instagram: wescuddles |
03-27-2013, 10:27 AM | #10 |
Rep 2,387
The price range on DP's is really amazing. At the low end $149 OBX, the high end $1500 Akrapovic. Funny there are no dyno comparisons...none
I bought a set of Xi OBX's just too look at them. Needed a lot of dremeling inside and flow/welds did not look so good. 2.5" all the way. Ended up buying some VRSF's for like $360 shipped (can't remember exactly). Looked like same basic material (304?) as the OBX's but had a bigger/wider bell area tapering into 2.5" about 1/3 way down, much better flow (eyeballing them) and fit pretty well. Also came with good gaskets and higher quality hardware. OBX's I never did install even after 2 hrs dremel work. Mainly I read a lot of people having fitment issues with them and I did not want to find that out mid installation. YMMV but I can't see ANY engineering, durability, or performance case for DP's costing more than $400 or so. Unless it is the soothing peace of mind you get knowing you've paid a great deal of money for some pipe. |
03-27-2013, 10:32 AM | #11 |
2097
Rep 43,350
There's a bit of detail when comparing the OBX to any reputable brand, the OBX build quality is a bit worse which has been known to lead to pre-mature failure, their SS material is actually 200 grade stainless rather than the 304 they occasionally claim and their flange material is generally always coated mild steel.
These things may not matter if you're only using the pipe for a year or so, but if you want something that's going to last more than a couple years and then still retain resale value, the material is what I'd be concerned with. Assuming the pipe fits of course Last edited by Tiago@VRSF; 03-27-2013 at 10:43 AM.. |
03-27-2013, 10:38 AM | #12 | |
Rep 2,663
Material makes all the difference. Then fitting..Then design
03-27-2013, 10:46 AM | #13 | |
Rep 2,387
03-27-2013, 10:53 AM | #15 |
Rep 2,387
03-27-2013, 12:30 PM | #17 |
3442
Rep 79,211
American Welding and Labor cost a lot more then overseas labor.... just a heads up for people wondering why there is a cost difference. Sometimes it's a quality issues or fitment issues and other times it just depends on who's making the product.
03-27-2013, 01:06 PM | #18 |
Rep 36
As an engineer, I certainly appreciate the differences in metal selection, as well as proper welding techniques and good basic design. That said, I would like to see a dyno comparison that shows a difference, real world, between the bargain basement pipes, the cheaper ones that are made of good material, and the holy grail downpipes which evidently cure cancer and add a couple inches to your manhood. Until we see some real data, I think it's really just enthusiastic championing of a design that most people really do not understand the flow characteristics of. *shrug* Just my opinion, but hey, I've only done flow modeling, balancing, and work on fluid systems for the Department of Defense for 11 years. Just because in theory there is a difference doesn't mean that in the real world you can even tell that difference exists.
03-27-2013, 01:30 PM | #19 | |
Rep 156
Drives: '07 E90 335, '04 R32
I think the point is pretty well represented that there is not going to be any difference. Intercoolers are even worse, these units selling for $1000-$1200 look SHOCKINGLY similar to VRSF's that is $400.
Boils down to if you want to support an American built product vs. an Asian built product. I don't really mind as long as the quality is there. I have VRSF DP's and am getting ready to order a new FMIC as well. Quote:
03-27-2013, 04:19 PM | #20 | |
3442
Rep 79,211
The differences are materials, wedling, and labor cost. However, there are certain attributes that are different in design but none will make a lanslide victory in terms of performance. Some downpipes taper to 2.5 earlier then others. Others have a cast bell mouth inlet. To name a few. It's a popularity contest for the most part. Just being brutally honest. |
03-27-2013, 04:34 PM | #21 |
Rep 36
Oh I know it would be a waste. I wouldn't be a very good engineer if I didn't already know that. The point is, for those extolling the virtues of the high priced items, do they have any data for their assertions, or is it all because of a warm fuzzy feeling? I know the answer and you do too.
You know the rules though, keep repeating something enough and it's a fact. Right? |
