E90Post
Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > UK > UK Technical Forum > Should I be concerned ?
Reply
      03-27-2013, 04:13 AM   #1
2funky4u
2funky4u's Avatar
Drives: BMW 335i SE Coupe
Morning All.. Started the 335i this morning and noticed a rattling sound coming from the engine on start-up. Note the start-up was from cold. Wasn't sure if this is normal or whether it points to something like the wastegate rattle issue ?
Would appreciate some advice.
The first Video (hopefully the link works!) - is when I started the car from cold and instantly took the video.
Video 1
The second video is when I pulled it out of the garage after about 3 mins or so, still idling.
Video 2
BMW 335i SE Coupe :: Black :: 2006
External Mods : Boot Lip Spoiler
      03-27-2013, 05:02 AM   #2
Mitch.
Drives: 335i
Is the noise in the second video coming from the passenger side?
If so, I believe it is a fuel venting solenoid, (not sure on the exact name) and is a common problem on the N54. It is located somewhere under the inlet manifold. There are a lot of videos on YouTube of the same noise.
I also have this noise occasionally, sometimes it does it, sometimes not.
Many people say it's a noisy injector, but the injectors are on the other side (off side) of the engine.
      03-27-2013, 05:13 AM   #3
djgandy
djgandy's Avatar
146
Drives: E93 M3
2011 M3  [0.00]
That second video sounds like a rapid firing gas hob igniter!
Mine had weird noises when I got it, seems to depend on temperature, day of the month, what I had for breakfast.
Keep an eye on it, if it doesn't go away when the weather warms up, maybe sometime in September at this rate then i'd be a bit more worried.
      03-27-2013, 06:01 AM   #4
phil200tdi
phil200tdi's Avatar
Drives: 335i M Sport E90 LCI manual
Normal - Injectors make a clicking noise at idle, second video is showing the fuel pump.
If the car runs fine and is hitting boost targets then there isnt a problem. Dont go looking for a problem which doesn't exist!
Car: e91 330d with Viezu map
Gone but not forgotten: 2010 Jaguar XFR (Cat-back exhaust, pulley, intake mods and map), Highly Modified E90 335i LCI M Sport Manual (circa 480BHP/500lb ft)
Reply
e90post
