Washer fluid leak?
03-29-2013, 02:59 PM | #1 |
Red Liner
10
Rep 129
Washer fluid leak?
So I've noticed my cars washer fluid level is always low very short after filling it.. So I fillied it about a week ago and made sure I didn't use it.. Then of course *BING!* washer fluid level lower.. Is this a common problem?
07' E92 328xi (First BMW)
09' E92 335xi (Current Car) |
03-29-2013, 03:08 PM | #2 |
FSAE Dude
62
Rep 759
hmmm. ive never noticed that on mine.. but you could probably check without too much trouble... idk if it would be more likely that the leak is in the tank or the lines to the windshield.. maybe just a loose connection
2007 TiAg 328xi: AA Tune, AFE intake, Full exhaust, 335xi Brakes, H&R RSB, UUC FSB, H&R Sports, Billy Sports...BBS SR 17x8
1985 Gazelle Beige 325e: Poly everything, e24 3.25 LSD, 225 lb weight reduction, Corbeau FX1, Shifter machined by me, roll bar, harness, all the other goodies. My "Racecar"...15x7 BBS RA |
03-29-2013, 11:39 PM | #3 | |
Red Liner
10
Rep 129
03-30-2013, 12:00 AM | #4 |
Rep 1,598
Mines leak, I filled it up and hours later I was low again but I found where the fluid was going. I saw it leaking from the passenger side under the sideskirt near the jack point. I'm going to take off my wheel and fender liner tomorrow and see why it's leaking. Hopefully it's just a loose hose.
03-30-2013, 05:04 AM | #5 |
Rep 450
Headlight washers are likely to leak.
06 330i 6mt Spt- Eibach Springs, BMW Perf Susp, Supersprint Exhaust, BSW Audio
RIP-94 325i 5mt 4d- M3 springs/susp, Z3 wheels, Chipped, Intake, Exhaust= FUN! |
03-31-2013, 07:23 AM | #6 |
Rep 51
Water dripping from the r/h side lower fender or door sill toward the front will be washer fluid/water. Mine did it and it was the pump shaft seal. Cost about $20 to buy a new pump and about 30 minutes total to replace.
04-01-2013, 06:41 PM | #8 |
Comfortably Numb
648
Rep 654
Drives: '18 x1/'13 X3/'06 330i
Followed the instructions from the link below and it took approx half an hour to complete. Maybe try this and filling up and running the washer to see if you can spot the leak.
Could possibly be a crack in the reservoir it's self. Would also be a good time to clean the filter. http://www.e90post.com/forums/showth...sher+reservoir
06 e90 330i/Alpine White/Terra Dakota
13 F25 X3 xDrive 35i/Black Sapphire Metallic/Oyster Nevada 18 F48 X1 xDrive 28i/Black Sapphire Metallic/Black SensaTec |
