How do you remove this brass connector on the intake manifold? 335i
04-01-2013, 12:44 AM | #1 |
Rep 1,465
Does anyone know how to remove this brass connector on the intake manifold throttle body?
i couldn't remove it. Couldn't get the manifold to come off completely, if i don't remove this. |
04-01-2013, 12:48 AM | #2 |
Rep 535
When I pulled my manifold I unbolted the throttle body from the manifold itself so I never had to remove that. It's pretty easy as it's only 4 bolts.
04-01-2013, 12:48 AM | #3 |
Rep 510
If you are facing the front of the car, you will need to sqeeze at the 1'oclock and 7'oclock positions, and pull it out. squeezing at these positions allows the connector to be pulled out.
'2018 F87 M2 LCI | LBB | GC Camber Plates | Ohlins R&T 90/190N/mm | 18x10 et33 square 275/35 | MPe | Poly Transmission Mounts | Recaro Sportster CS
04-01-2013, 12:53 AM | #4 |
Rep 1,465
But I don't understand guys, he bolts are facing upwards on the throttle body so how could I remove it? blindly? it was very tight/hard to reach.
the manifold wouldn't come off, i could only get it to reach the end of the stud but that's only 1 inch apart from the engine block. I wanted to change the intake manifold gaskets out at 66k miles but couldn't do it. Do I squeeze the black rubber grip thing? Also, does the brass fitting stay put and the hose part come off? I heard that the intake manifold nipple is commonly broken off and cost a lot to fix. Is this the infamous "nipple" everyone is talking about? |
04-01-2013, 01:00 AM | #5 | |
Rep 510
04-01-2013, 01:04 AM | #6 | |
Rep 1,465
there's a high degree/risk of breaking these I suppose? how do I remove it properly? any pictures? |
04-01-2013, 06:52 AM | #7 |
Rep 1,520
Squeeze the connector and push it forward on to the TB first then pull it back. Usually makes it come off easier working it back and forth this way.
On the vacuum nipple I just remove the vac line from the T at the diverter valves and pull the intake leaving the line attached to the nipple. |
04-01-2013, 12:44 PM | #8 |
Rep 36
It's not a big deal to just remove the throttle body and maneuver it a bit in order to more easily see the piece you're trying to remove, which can be difficult, but everything is on this car.
On the back side of the manifold almost at the aftmost end is a clip holding a wire/connector, don't forget to pop open that clip and remove the wire prior to ripping the manifold off. There is a vacuum line attached to a nipple just aft of the throttle body area. This line goes to a "Y" branching to your diverter valves. Good idea to replace the line, just cut it and remove the remaining vac line from the nipple once the manifold is off completely. IMO best way to do it is to use a utility knife to slice the dried up vac line parallel to the nipple, then just gently peel the old line off -trying to yank the line off, especially if it's not perfectly aligned, is a great way to break that nipple. Also, I suggest paying close attention to how you remove the manifold since, in my experience, 100% of the time it's a PITA to fit back in. |
