BIMMERPOST Universal Forums Off-Topic Discussions Board Any Electrical Engineers out there?
      09-06-2007, 03:55 PM   #1
TOPHER325
Drives: 87 325is
I am trying to put together a simple wireless system using a button and some transmitter and reciever components. I can't figure it out. If any of you have a knowledge of this stuff I would GREATLY appreciate some help. I can email spec sheets on the components and some drawings of what I am trying to do if you think you might be able to help me out.
Thanks in advance...
      09-06-2007, 03:59 PM   #2
MadDog
Careful, I Bite.....
MadDog's Avatar
Drives: 2006 325i
2006 325i  [7.50]
Is this some off-the-shelf stuff, or are you trying to design it yourself ?? I'm not an electrical engineer (I'm software), but I have a fairly good knowledge of hardware.
MD
      09-06-2007, 04:21 PM   #3
TOPHER325
Drives: 87 325is
its OEM transmitter and reciever from Linx Technologies and i want to use a Bulldog button from Polara. The transmitter already has buttons but i have to solder in wires for the polara button.
      09-06-2007, 04:33 PM   #4
MadDog
MadDog's Avatar
Drives: 2006 325i
2006 325i  [7.50]
Does the receiver and transmitter work now ??
So, if I understand your problem, you just want to use a different button on the transmitter.
Can you post links to each of the components ??
MD
      09-06-2007, 04:55 PM   #5
TOPHER325
Drives: 87 325is
Transmitter (Model # CMD-HHLR-418)- http://www.linxtechnologies.com/Prod...d-Transmitter/
Receiver (Model # FCTN-RLY4-418) - http://www.linxtechnologies.com/Prod...nction-Module/
Button (Bulldog) - http://www.polara.com/BD_Features.htm
The button is powered from a 9V battery and the transmitter has it's own 3V supply. The receiver is powered from a land line. I know there needs to be a 5V relay (from RadioShack) somewhere in the wiring too, as well as a Resistor (also from RadioShack).
There are two button and transmitter assemblies, each in a 'pod' about 50' away from the reciever.
