What size oil filter cap tool for E90 320i?
04-06-2013, 08:19 AM | #1 |
Rep 224
Hey guys,
I've just spent the morning doing the basic service on the E90. The cabin filter, air filter are both done but have had huge difficulty getting the oil filter cap off... have tried leather straps and everything. The top of the oil filter requires a special tool to get it off (below) have been on to BMW about this and they do not sell to retail, contacted a local parts store, they don't sell. There are various tools/wrenches online for this but just wanting to know what size you guys are using? I have measured and it seems the cap is 86/87mm? Does anyone have this wrench/tool and if so, what size is it that I need? Last thing I want to do is order incorrect part and have to wait longer to get this done Thanks |
04-06-2013, 09:30 AM | #2 |
Rep 224
For anyone finding this thread and needing help.... there are many different sized wrenches so to avoid buying the wrong size (rough measurement is 86mm but it could be 87mm) I went to this website:
http://www.lasertools.co.uk/item.aspx?cat=0&item=3597 From here I then found this wrench can serve a variety of different engines: BMW N40, N42, N45, N46, N52 so I then went to: http://www.bmwheaven.com/database/show.php?id=20 And there I found the engine for my E90 320i was N46, so the tool: 4234 Oil Filter Wrench from Laser is the correct size - 86mm. There are 87mm wrenches knocking about which are labeled as working with BMW but always check with this method to avoid disappointment. Can finally get oil changed when this thing arrives! |
04-06-2013, 12:41 PM | #3 |
Rep 3,201
Drives: E92 325i MSport Coupe
Hesitate to disagree, but I don't use a special tool at all. A normal strap wrench will grip the flats on the housing cap sufficiently to get it moving. Then you can undo by hand.
E92 pre-LCI 325i - Ohlins R&T; H&R spacers; M3 strut brace; Swift thrust sheets; 3 x chassis braces; diff brace; N53 V-brace; 034 subframe inserts; BMS clutch stop; BMS CDV; RE g/box mounts; Delrin shift bushes; Saikoumichi OCC; Cyba scoops; BMW Perf Exhaust; HEL s/steel brake hoses; M3 rear spoiler; Recaro Sportster CSs; M3 white dash LEDs; LED Angels; LED side repeaters; BMW Perf black grille; CSL reps; SSDD carbon diffuser; Monster Wrap black roof/clear front
04-07-2013, 04:01 AM | #4 |
Rep 2,216
Drives: E91 330d M Sport
I bought a set of oil filter wrenches years ago when I started doing my own servicing. Think they're Laser but not 100%. Pack of 5 has done every car I've touched since.
04-10-2013, 07:15 AM | #5 | |
Rep 224
Sadly the strap wrench method wouldn't work for me due to some balloon head over-torquing. Still waiting on the tool to arrive so that I can get this thing off! |
04-10-2013, 07:24 AM | #6 |
Rep 3,201
Oh dear. Hope you get it sorted...
04-10-2013, 01:40 PM | #8 |
Zummerzet Zyder Drinker!
112
Rep 5,541
Drives: '06 330D Le Mans Blue
Pervert!!
04-24-2018, 03:51 AM | #11 |
Rep 94
If its the same as the 320i, it will be 16-flute , 86mm measured across the flats (88mm measured across the 'points')
Amazon sell the 86/88mm laser tool no. '3119' for £6.odd, works well.
2010 E91 320i MSport
VW Corrado VR6 |
