SoCal Track Day! Chuckwally Raceway 05/04-05/05: 05-04-2013
04-10-2013, 02:40 PM | #2 |
Rep 124
Drives: e92 335
The term 'socal' gets used pretty loosely!
04-10-2013, 03:32 PM | #3 |
Rep 15,818
Anything below SF is Socal right? lol
04-11-2013, 02:32 PM | #4 |
Rep 124
Drives: e92 335
Lol yeah you're right, socal is so big we should put sections to make it easier
04-11-2013, 10:38 PM | #5 | |
Rep 15,818
lol
04-12-2013, 02:45 AM | #6 |
Rep 15,818
For those that are interested in the Competition, here's the info direct from their site (i just copied and pasted it):
Competition Dates Apr 20th Big Willow Springs May 4th Chuckwalla May 26th Streets of Willow June 15th Big Willow Springs Aug 24th Streets of Willow - Night event -4pm till Midnight Sept 28th Chuckwalla Nov 23rd AAA Speedway Dec 7th Buttonwillow Raceway Dec 21st WSIR Suspension: 0.50 pts- OEM Springs w/aftermarket Shocks 1.00 pts- Aftermarket springs w/OEM Shocks 1.25 pts- BMW suspension Upgrade (M Suspension pkg on Non-M Suspension) 2.25 pts- Single adjustable coilovers suspension 3.25 pts- Double adjustable coilovers suspension 5.00 pts- Triple adjustable coilovers suspension 1.75 pts- Each adjustability (after triple only) 1.50 pts – Aftermarket front sway bar 1.00 pts – Aftermarket rear sway bar 5.00 pts – Aftermarket active suspension (OEM active suspension acceptable) 4.00 pts – Relocating suspension pick up points Engine & Power 0.25 pts –High-flow cat 0.50 pts - Catalytic Converter removal 1.00 pts –Headers 1.75 pts – Intercooler 2.00 pts – Modified cooling components location (radiator, oil cooler, diff cooler, etc) 1.50 pts –Intake manifold (Including swaps) 1.50pts- Cat-back exhaust 2.00 pts- Turbo downpipe 1.00 pts- Aftermarket ECU reflash/chip (N/A motors) 3.00 pts – Aftermarket ECU reflash/chip (turbo motors) 5.00 pts- Aftermarket force induction (turbo and supercharger kits) 3.00 pts – Modifying existing turbos (including wastegate) 3.50 pts- Standalone units 1.50 pts- Aftermarket upgraded camshaft 2.50 pts – Internal engine modifications (including rods, camshaft, pistons) 4.00 pts- Bore and stroke modifications 3.50 pts- Nitrous Oxide System 0.00 pts – Engine swaps will be automatically bumped into engine category Wheels, Tires, & Brakes 0.00 pts – Wheels 1.75 pts – Brake ducts 0.75 pts – Aftermarket brakes pads 0.75 pts – Upgraded BMW sliders & calipers 1.50 pts – Front big brake kits 1.75 pts – Front and rear big brake kits 0.00 pts – Street tire UQTG treadwear rating at 140+ -1.00 pts – Street tire UQTG treadwear rating at 220+ 4.00 pts – Street tire UQTG treadwear ratings at 100+ 6.00 pts – Street tire UQTG treadwear ratings at 80+ 8.50 pts – Street tire UQTG treadwear ratings at 40+ 1.50 pts – 10mm above class max size 3.00 pts – 20mm above class max size Aerodynamics 0.50 pts – Modified front bumper (including aftermarket & CSL splitter) 0.50 pts – Modified rear bumper (including aftermarket ) 0.50 pts - Modified & aftermarket trunk 0.50 pts – Modified & aftermarket hood 2.00 pts – Front splitters (under 3inches) 3.50 pts – Front splitters (over 3inches) 1.00 pts – Canards and dive points 1.50 pts – Modified & aftermarket rear diffuser 2.50 pts – Flat underbody w/diffuser 0.50 pts – Aftermarket or upgraded OEM trunk spoiler/lip 3.00 pts – Aftermarket wing (up to 60inches wide) 3.75 pts – Aftermarket wing (over 60inches wide) 5.00 pts – Multi elements &/or active wings 0.50 pts – Gurney Flap 2.50 pts – Wide body/ over fenders, body kits Miscellaneous 1.50 pts – Differential changes (Ratio, LSD, Lockup) 1.00 pts - Aftermarket steering wheel 1.50 pts – Aftermarket flywheel & clutch 1.00 pts – Weight reduction ( per each 100 pounds)
04-28-2013, 07:30 PM | #8 |
Rep 15,818
