04-12-2013, 12:50 PM | #1 |
Rep 197
M suspension vs adaptive
Does anyone have any feedback on the differences between these two types of suspension. I currently have the Msport suspension, but I'm looking to upgrade to the adaptive. Msport suspension just sits too high. Does anyone have feedback as to whether or not it's worth it? Or any feedback at all?
Thanks |
04-12-2013, 02:06 PM | #2 |
Rep 4,553
You cannot upgrade to M Adaptive suspension, provided your car has already been built. M Adaptive has wiring harnesses that go to each strut and you won't have any of those harnesses in your non M Adaptive car. Not to mention the module(s) and other parts that go along with it.
I think you'll want to look at the M Performance suspension kit. http://www.getbmwparts.com/partlocat...subcat1=183175
2023 840GC | 2021 740i | 2019 X3
04-12-2013, 02:07 PM | #3 |
Rep 876
I'm not sure it's feasible to upgrade M Sport static suspension to M Sport Dynamic Suspension. There are several lowering options available, that's really your only choice in regards to dropping the car some. The Static and Dynamic suspension both have the same ride height anyway.
04-14-2013, 06:51 PM | #4 | |
Rep 7,047
I don't think it would be worth the cost to retrofit the adaptive dampers. You'd be better off getting the BMW M Performance suspension. If you want a lower ride height, then look into either an aftermarket set of springs, or perhaps the M Performance springs. The M Performance springs are lower and firmer rate as most aftermarket springs are. The full M Performance suspension kit comes with different dampers and a lower and firmer set of springs. Some owners with the M adaptive system have gone with aftermarket lower and firmer springs with positive results. And also owners with the sport suspension have gone with aftermarket lower and firmer springs with good results. The sport and M adaptive suspensions are very similar in that they use the same ride height springs, and the spring rates are very likely to be the same or near same. When setting the M adaptive to full sport mode it doesn't feel any firmer than the sport suspensions static tuning. The difference is that the M adaptive can "adapt" the internal damping circuit using electronically controlled valves, so that there is better damping control over different surfaces and bumps. I have M adaptive on my Msport and comparing it to the standard sport suspension I don't feel too much difference, but that's because I haven't had extensive comparison time on a variety of surfaces. The adaptive dampers offer the ability to improve damping, and the greater difference is that one can set the adaptive suspension to 'comfort' mode, which results in a noticeably smoother ride on rougher surfaces and highway cruising. But, the trade off is that there is more body roll and leaning in harder turns. BMW missed the boat on this one. The M adaptive suspension offers not much, if any, better "sport" performance over the stock sport suspension. It would be a much better value if the M adaptive was between the stock sport and M Performance suspensions. The springs should be at least 20%-25% firmer over the sport set up. |
rfcoolz39.00 |
04-14-2013, 08:18 PM | #6 |
Rep 1,544
04-17-2013, 06:04 PM | #7 | |
Diligentia Vis Celeritas
558
Rep 1,477
Drives: 335i
Regarding the M Adaptive suspension... I'm still a little fuzzy on how it fits into the line-up on the different cars. Is the M Adaptive suspension technology just an add-on that interacts with whatever dampers are on the car? Or is it a complete kit with special dampers/springs, etc. on whatever vehicle it comes equipped on? For example, on a RWD M Sport F30, you get the M Sport suspension, and you can opt for the M Adaptive suspension as well. On an xDrive M Sport F30, the M Sport suspension is not included - but you can still opt for the M Adaptive suspension. Would these two cars be running on the same dampers? (Maybe just the springs are different, which would account for the ride height difference...?) Or are the dampers themselves different on RWD vs xDrive applications of the M Adaptive Suspension as well? Basically, I would prefer to go with an xDrive F30, but I don't want to sacrifice much (if any) in terms of handing capabilities. I would be willing to do a little work aftermarket (stiffer springs, stiffer ARBs) as long as it's not too expensive, but I'd rather avoid spending thousands on a whole new suspension. |
04-17-2013, 06:20 PM | #8 | |
Rep 4,553
04-22-2013, 11:31 AM | #9 |
Jenkspj
Rep 8
Drives: SOON: BMW 320i Xdrive Touring
Thanks to RPM90 and others for making this clear.
I'm on the point of ordering a new M Sport F31 Touring with x Drive and was wondering if I should go with the Adaptive suspension. It seems that the comfort mode gives the driver a stock non M sport ride as an option: useful on what pass for roads in South Wiltshire. I have - not for much longer - and Evoque with adaptive dampers and it makes a big difference. Any other input on this question very welcome! |
04-22-2013, 12:01 PM | #10 | |
Rep 4,323
CURRENT: 2017 RS3 (miss you guys)
SOLD: 2012 335i Mineral Gray M Performance Exhaust/Brakes/Suspension/LSD|Bav Stage 1/AMP||ER CP/IC/DP/OC | Dinan CAI/N55 PWG BIG TURBO|BMWF30.com |
04-24-2013, 01:48 PM | #11 | |
Rep 1,037
From what most people on this forum say, the std m-sport suspension is plenty compliant in comfort mode. If the only benefit of adaptive M suspension is in comfort mode (and all it is in electronic actuators, no actual mechanical difference), then what's the point? Now, if you start adding aftermarket springs/coilovers, that poses a different question.
2014 335i RWD: ZMM, ZDA, ZDH, ZPP, ZTP, 2NH, 2TB, 5DL; Z4A MPPK; AW ext / VB int
04-24-2013, 02:00 PM | #12 | |
Rep 4,323
The M performance is valved more aggressive than the M Sport...
04-26-2013, 07:30 AM | #13 | |
ti fan
67
Rep 273
Drives: 14 12C | 17 X5 50i | 19 M2C
Garage List 2014 McLaren 12C Sp ... [0.00]
2017 BMW X5 xDrive50i [0.00] 2019 BMW M2 Competi ... [0.00] 2008 BMW 535xi Touring [10.00] 2008 BMW 135i [10.00] |
The best part, though, is when you are cornering you can feel the inside front shock tighten up and reduce roll through the corner. |
04-26-2013, 12:59 PM | #14 | |
Rep 1,037
i also researched further that it seems that the M peformance springs are not compatible with the adaptive suspension, only the std msport suspension.
04-27-2013, 07:40 PM | #15 | |
Rep 7,047
In terms of all around suspension firmness, which is more about the spring rate. Even pro reviewers have said the same thing I am saying, which is that the adaptive system set to sport is as firm as the standard non adaptive sport suspension. But that really need to be better explained and it needs to be understood that there is still another advantage to the adaptive dampers that the standard sport can't do, and that's that the dampers can alter their internal valving to better compensate and control the springs movement over different road surfaces. That is the big benefit of the adaptive damper over the standard sport damper. As you describe the system can firm up the valving in certain situations to adapt and control the springs over a wide variety of road conditions, where the standard system is always using the same non adaptive valving. However, is the M adaptive valving any firmer at it's firmest level compared to the standard sport dampers? That's where I and others say it is not. At it's firmest valving the M adaptive and the standard sport feel pretty much the same. The difference is that the M adaptive can apply a wider range of variable damping control over different roads surfaces. Ride firmness/stiffness is mainly based on the spring rate, and since both systems have pretty much the same springs the firmness will feel pretty much the same. How that spring's motion is controlled is where the adaptive damper has the advantage. For example, on sharper hits the valving can quickly alter allowing the spring to compress faster and further before the damper grabs it, which can be felt as better compliance over sharper bumps. The non adaptive can't compensate and thus may feel harsher over the same bump. Also, the adaptive damper can alter it's rebound valving to compensate for road surface and can either slow down or speed up the springs rebound, thus giving a potentially better all around suspension. There is also of course the more noticeable effect of setting the adaptive to "comfort" mode, which allows the internal valving to allow even greater spring movement resulting in a softer smoother ride compared to the standard sport suspension. I didn't mean to imply that the M adaptive suspension has no benefit over the standard sport. I just wanted to point out that the M adaptive is not really a "firmer" sport suspension compared to the standard sport suspension as the M adaptive doesn't have firmer rate springs nor shorter springs. But, the M adaptive does possess the ability to have "firmer" valving if and when needed, and that makes it a better all around suspension. Is it worth the added cost of $1000 along with the variable ratio steering? I don't think so. I did it as I am leasing so the actual cost is less than $1000 to me. If I were buying to keep my 3 series I think I would spend that money on getting the M performance suspension, which would really make a difference. I hope that makes it clearer. Last edited by RPM90; 04-27-2013 at 07:50 PM.. |
Poochie9106.00 |
04-27-2013, 08:00 PM | #16 | |
Rep 7,047
The M performance suspension is a kit that includes new springs and dampers designed to work with those firmer springs. I'm looking into just putting on the M Performance's stiffer springs and retaining the M adaptive dampers. That's pretty much the same thing as someone keeping the stock sport dampers and getting an aftermarket firmer set of springs. By keeping the M adaptive dampers I'll retain the advantage of self adaptive damping, along with being able to select a softer long distance ride. The problem that could arise is that the M adaptive dampers won't have enough damping range to fully control the firmer springs, so that it could become over sprung and under damped, or too heavily sprung and under damped. That ride would be annoyingly bumpy. But I don't think that would happen. The only way to know is to try it. Some of our members have installed shorter and firmer after market springs and kept the stock sport dampers and have reported great and very acceptable results indicating that the M adaptive should have enough range to handle the M Performance springs, which are about as firm as the after market. I'm hoping someone will try this first so that if it doesn't work I won't have wasted money. |
05-07-2013, 11:14 AM | #17 |
Rep 383
Can someone explain the difference between the different suspensions? I have the modern line. What's the difference between my car vs the sport line? Sorry for the noobness.
05-07-2013, 07:38 PM | #18 |
Rep 1,029
the sport has firmer springs so car sits lower and handles better, and it has beefier sway bars.
05-07-2013, 08:14 PM | #19 |
Rep 1
I'm looking to purchase a 320i M Sport XDrive and have found out that with the XDrive the normally standard MSport suspension is not available, but you can add the MSport adaptive for around £500. Is it worth it?
Also is it better bought with the 18 inch wheels rather than the 19 inch. I've read elsewhere that the 18inch work better with the adaptive sports suspension. Feedback appreciated. |
05-11-2013, 07:21 PM | #21 | |
Rep 7,047
In the US market you can get the M Perf suspension put on a Sport line and on an Msport as long as the Msport does not have the M adaptive suspension. The Msport does NOT come with the M adaptive system, that is a separate option that comes in the DH/dynamic handling pkg. that includes VSS, that's in the US market. I don't think the M adaptive comes on the Msport in any market as it's an options item. |
05-11-2013, 07:28 PM | #22 | |
Rep 7,047
Here's some info I posted in a different thread. "I recently found this post and found it interesting, and think others may find it interesting as well. I can't confirm the information. I was not aware of some of the differences with the M adaptive suspension compared to the standard sport suspension. Here is the post: Looking at realoem it appears that one difference between the m variable suspension and the regular sport suspension is sway bar size. The comparison is 22mm sport, 22.5mm m variable (front). Rear sway bars appear to be 22mm sport, 23mm m variable. Assuming this is correct, I ordered my F30 with the M variable suspension as it may (note cautious hedging there) have a tad less understeer and slightly less body roll. Not that I would ever use my BMW in a way to appreciate those distinctions but it is just a nice theory " That poster claims that realoem shows a difference between sport and Msport. What is your source for those items being identical? |
