Air Pressure at the Track
04-15-2013, 01:46 PM | #1 |
Rep 62
Drives: e28 533i, '11 335is, '12 911 S
Just curious, what kind of air pressure are you running at the track?
Please state tire size, tire make/model, air pressure, and whether that measurement is taken while the tire is hot or cold. Include outside temp if you like. Thanks! |
04-15-2013, 02:04 PM | #2 |
Midlife Crises Racing Silent but Deadly Class
1821
Rep 5,337
Drives: 2006 MZ4C, 2021 Tesla Model 3
You're opening a whole new can of worms...Tire pressure is like ssholes, everyone's got their own favorite.
I shoot for 36psi "hot" as measured in paddocks immediately after 1 cool-down lap. Should translate to ~37-38psi true hot. Nitto NT-01 245/40/18F 275/35/18R. (* My typical interpretation of a "cool-down" lap involves driving a lap without engaging the brakes but still corner at max speed through turns)
Sitting on a beat-up office chair in front of a 5 year old computer in a basement floor, sipping on stale coffee watching a bunch of meaningless numbers scrolling aimlessly on a dimly lit 19” monitor.
04-15-2013, 02:29 PM | #3 | |
Rep 864
Drives: '08 E92 335i
Your particular pressure is going to vary based on the type of tires you use, your driving style, and your desired car balance (you can tweak the balance a bit by running slightly higher front/rear pressure). |
04-17-2013, 01:57 PM | #4 |
Rep 595
I target about 40psi hot. Yokohama Neova AD08, 255/35/18 all around.
For autox, I stick with 45psi hot. Same tires.
05-16-2013, 03:43 PM | #5 |
Rep 1,470
32 cold and 37 hot is my goal.
auto-x pressures are totally different than road racing.
Stoptech 380mm/355mm | PFC08 / Pagid RS-29 | Akrapovic EVO - CF tips | Benvo Tune | MS UDP | AA air filter | MCS 2-way with 700/1000lb springs | Solid bushings and adjustable links | RD front swaybar | Apex EC-7 18x10 square 275/35-18 NT01 | Turner Race Studs | GT4 Brake Cooling | GT4 Power Steering Cooling | Alekshop Oil Cooler | Performance Steering Wheel | | CF Spoiler | Varis System 1 Full CF Diffuser | Extended Paddle Shifters | Schroth Quick Fit Pro | Turner Steering Rack Stops | Vorshlag Camber Plates
05-23-2013, 10:02 PM | #7 |
Rep 8
Drives: 2011 Bronze 328xi Wagon
Depends on the weather. I have Michelin Pilot Super Sports on my 2011 328 wagon. For 2 - 3 mile track event, in cold rain, 34 all around. With bright sun, 32 all around. Those are cold readings.
05-28-2013, 12:31 PM | #8 | |
Rep 45
That said, COLD readings are worthless. Any pressure you measure as a reference needs to be hot, the sooner after the car pits, the better. Hot readings are the only way to accurately know what the tire is doing when on track. |
