04-21-2013, 02:14 AM | #1 |
[Versatile]
378
Rep 1,683
3 inch DP vs. 4 inch DP for 335i?
BMS makes a 4 inch DP and Challenge, just to name one has a 3 inch DP. Which one is better for the F30 335i?
This is just about 3 inches vs. 4 inches. I know catless and high-flow cats play apart in the decision but lets save that for a later time.
'02 TS E46 330xi - SOLD
'06 SGM E90 325i - SOLD '13 AW F30 335i ///M-Sport 6MT. OEM(+) - SOLD '20 AW F87 X3MC - Sold Current: `23 Chalk G80 M3CX | Ordered: '24 M3CS - Week37 build. |
04-21-2013, 10:09 PM | #2 |
Rep 1,339
I got the Evolution Racewerk 4inch one, i would assume the 4inch would have better flow and being it less restrictive.
2013 F30 335i xdrive | Estoril Blue | Black Dakota Leather | Aluminum Hexagon trim | M-Sport | Cold weather | DHP | Premium package | Tech package | Harmon Kardon | PDC | Rearview Cam | IND Painted reflectors | BMW performance grills | JB4 stage 2 | ER downpipe | BMS Intake | H&R sport springs
04-21-2013, 11:29 PM | #3 |
Professional
50
Rep 977
Obviously 4" would be less restrictive but there is a point in which you would not see any more gain. 3" vs 4" pressure drop and velocities reach a point where they are not restrictive for the given vapor flowrate. As a general rule of thumb pressure drop is equal to the square of the velocity. Which means, say you dropped the velocity of the vapor by 2x, the pressure drop you actually dropped is 4x!
So, the area of a 2" pipe is 3.1 sqin while the area of a 3" pipe is 7.1 sqin. The area of a 4" pipe is 12.6" sqin. Bernoulli's equation could be used to calculate the pressure drop. Exhaust tweaking is all about reducing pressure drop/backpressure is what I figure. |
04-22-2013, 01:12 AM | #4 |
[Versatile]
378
Rep 1,683
Good info guys. I'm also assuming the 3 inch dp will allow the N55 to keep some of the low-end torque where as the 4 inch dp will be better up top due to spool will be a bit slower?
04-22-2013, 02:02 AM | #5 |
Rep 1,400
Doesn't work that way for turbo cars. Backpressure is not needed for low or mid range power. Bigger downpipe faster spool and more power until efficiency maxes out.
04-22-2013, 08:44 AM | #6 | |
Rep 4,323
From a quality standpoint, the BMS one looks infinitely better....I just don't feel right running around without ANY cat at all, and since this DP deletes it all together, I'm reluctant to advise either. If BMS threw on a 200 cell cat into it, I'd pay the $$ and do it for sure...most of the gains they advertise are from the CAT delete.
CURRENT: 2017 RS3 (miss you guys)
SOLD: 2012 335i Mineral Gray M Performance Exhaust/Brakes/Suspension/LSD|Bav Stage 1/AMP||ER CP/IC/DP/OC | Dinan CAI/N55 PWG BIG TURBO|BMWF30.com |
04-22-2013, 10:21 AM | #7 | |
[Versatile]
378
Rep 1,683
04-22-2013, 11:31 AM | #8 |
[Versatile]
378
Rep 1,683
Just talked to a buddy who owns a car shop that builds a lot of cars and he says sticking to a 3 inch catless dp is better than going to a 4 inch dp in terms of making power on a stock turbo.
04-22-2013, 11:34 AM | #9 |
Rep 4,323
that's such a generalized comment (from your buddy) I can't even begin to comment on it...
04-22-2013, 11:39 AM | #10 |
[Versatile]
378
Rep 1,683
Well I didn't know how to write everything he said but it has to do with velocity trade offs with diameter and what not... Iono. Maybe I will have him write something on here when possible.
04-22-2013, 12:50 PM | #11 |
Rep 1,975
I can assure you guys that the Challenge quality is top notch.
2013 F30 335i ///M-Sport
Forgestar/Challenge/BMS JB4 Wagner/Evo Race/M-Performance 2016 F15 50i ///M-Sport BM3/H&R/Borla |
04-22-2013, 02:02 PM | #12 |
[Versatile]
378
Rep 1,683
Thats good to know. I wonder if Challenge offers thermal coating on their DP?
04-25-2013, 10:47 PM | #17 |
[Versatile]
378
Rep 1,683
04-25-2013, 11:17 PM | #18 |
Rep 1,400
04-26-2013, 06:48 AM | #19 |
Rep 1,975
I personally think the difference from 3"-4"-5" or whatever is negligible. But it does look like a quality product. For my needs, I still prefer the HFC option. On my white car, I get a little bit of exhaust soot on my back bumper and trunk after a few days and that's WITH the hfc. It's got to be a lot worse with no cat.
04-26-2013, 09:01 AM | #20 | |
Rep 72
2013 335i F30 N55
04-26-2013, 12:30 PM | #21 |
BimmerPost Supporting Vendor
4922
Rep 115,999
04-26-2013, 12:34 PM | #22 |
Rep 1,975
Your tips don't even turn black? That's pretty bad A
