E90Post
Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Oil cooler thermostat
Reply
      04-22-2013, 07:54 PM   #1
cleex024
Drives: 2008 BMW 335i Coupe
Hey guys...ive been reading up on removing the thermostat spring and valve for the oil cooler and seems very easy but has anyone tried to maybe just cut the spring maybe quarter or half a circle?
i feel like maybe then itll just open up a little early at maybe like 210-220 degrees. if anyone has tried this please comment below...recently got the er competition oil cooler but i dont want it to start cooling at 235 degrees and i dont want it to start cooling right off the bat as my car already takes forever to heat up.
thanks for the comments.
Space Gray l 6MT l OSG LSD w/ VAC Race Diff Cover l Cobb e30 l Morr vs8.2 l UUC SSK w/ DSSR l VSRF Catless Dps l RPI Intercooler l CDV Removed l HID AE 8000k l ETS Catback l AST 5200 w/ Vorshlag Camber Plates l ER Dual Oil Coolers l Rear Camber and Toe Arms l K&N Drop In l Solid Tranny/Diff/Subframe Bushings l Bridgestone RE-11
      04-22-2013, 08:05 PM   #2
max_k20
Bavarian Love
Drives: 230i xDrive
Or easier some company now offer some thermostat bypass that recirculate oil properly. Read many times that removing the thermostat wasnt working properly to act as a bypass.
08 FG2 Civic SI FBO - SOLD
09 E92 335i Xdrive FBO - SOLD
17 F22 230i Xdrive | Alpine White | Coral Red | M-Sport | BMS Intake | JB4 | 666M Rep | M Carbon Mirrors | Roof Rack | Daily Driven
      04-22-2013, 08:35 PM   #3
NY135ivishnu
Drives: 2009 bmw 135i
AR design sells a thermostat delete adapter. You can install this and use a external thermostat by Mocal that activates at 180 or 210 degrees. It's a bit more expensive but it's the proper way of doing it.
      04-22-2013, 08:37 PM   #4
max_k20
Bavarian Love
Drives: 230i xDrive
From what I read from AR you will need a new aftermarket oil cooler for it to properly run. We are now speaking 500-1000$ vs a 59$ part sold by mutliple vendor. I will swap mine out when winter come back (up here in canada) as its so easy to do.
      04-22-2013, 09:18 PM   #5
cleex024
doesnt really make sense that you would need to buy different oil coolers for a thermostat. either way stated in the OP i said that i just got the er competition oil coolers. so just looking for a way to starting cooling a little quicker.
i can see why the bypass doesnt work because if you open it up there is 2 channels obviously the in and out...and when the valve opens up it goes right in between the two making the flow only go one way. however if you pull it completely out then there is a gap there and it would interfere with flow.
however if you cut the spring to the right length it might open up a little quicker however maybe interfere with the exit side thermostat. ill tinker with it a little and let you guys know what i find out.
but more input would be greatly appreciated so we can all share some info. i dont know why people havent looked into this a whole lot.
      04-22-2013, 09:47 PM   #6
robc1976
DIYER
robc1976's Avatar
614
Drives: E90 335i
I use the 180 degree thermostat, love it!
JB4 G5, Stage 3 LPFP, Stage 2 MOTIV PI, VM 6466 ST, Custom OCC W/ SS lines, ER FMIC, ER CP W/HKS BOV, M3 control arms, M3 guide rods, M3 upper links, M3 front & rear sway-bars, HPA rear toe arms, Wavetrac LSD, HPF Gen 2, DEFIV kit, KW clubsport, Delrin solid SF bushings, stoptech rotors, Rogue Tranny Mounts, 1M bumper, M3 CF hood, M3 fenders, M3 OEM sideskirts, Mtech rear bumper, CSL trunk, MORR VS8.2 rims 245/295
      04-22-2013, 10:06 PM   #7
cleex024
where did you get it?
      04-23-2013, 08:05 AM   #8
NY135ivishnu
I got the same from racepartswholsesale.com
It's the Mocal low temp about 150$
      04-23-2013, 08:36 AM   #9
MDORPHN
Drives: AW 1M
I must say that I don't really get this lower thermostat stuff for an N54 -- especially if it has the stock oil cooler.
Under prolonged load, the car simply does not have sufficient thermal capacity to maintain the oil temp at whatever temp the thermostat opens up.
In other words, it doesn't matter whether the thermostat is 180 or 220, your oil temp will go higher.
Perhaps if you only drive on the street and never really push, you will run a bit cooler -- but you're not really stressing the car in that case, so who cares if the oil is 180 or 230?
What am I missing?
Neil
      04-23-2013, 09:34 AM   #10
cleex024
What am I missing?
Neil
you are missing quite a bit here...I do push the car hard almost everyday and couple track and hpde events a year...and if you read the OP i just recently got the ER competition dual oil coolers.
now if i install these with the thermo set at 235 degrees then the oil will heat up to that temp then start cooling which is a problem because when pushed hard the temps climb pretty quickly...however if you start cooling the oil at say 210 degrees then the oil will most likely stay at about 210 til pushed.
if you check your car watch the gauge rise to about 235 and just stay there while you cruise...so you can imagine with 2 monster coolers and thermo start at 210 then most likely the temps will stay pretty close to that number til pushed hard.
dont get me wrong the temps might still get to 250 but not much more than that and probably will get cooled on some straight aways at a track but if the cooling starts at 235 then the temps might rise to 260-270. basically you are cooling the oil sooner so you dont reach those temps if you can sort of understand my logic. i was sort of confused too but makes sense now that ive really looked into it and thought about it more.
anyhow with the er competition oil coolers i dont think the temps will hit over 260 degrees but i still think thats a bit too high...if i could keep my temps down to about 240-250 i would be happy obviously when im pushing the car hard.
      04-23-2013, 09:52 AM   #11
kenneth
kenneth's Avatar
Drives: 335i Sedan
Let us know what solution ends up working for you!
SB, Terra, 6MT. Only a few mods here and there.....nothing extreme!
      04-23-2013, 10:05 AM   #12
MDORPHN
Drives: AW 1M
Yes, that's why I qualified my post with a statement about a N54-motored car with a stock oil cooler and stock thermal capacity.
You (and I) have much greater thermal capacity, so a lower thermostat could produce benefits.
FWIW, before I replaced the stock oil cooler on my 1M with an RRT-fabricated Setrab-based system, I would see as much as 280-290 on track (time trials/instructor run groups) on hot days (VIR, MidOhio, Summit Point, etc.)
My temps have dropped approx. 25 degrees, though I must point out that my temps still exceed my thermostat's full open setting so I wouldn't realize significant benefits from going with a lower temp thermostat.
Neil
      04-23-2013, 11:44 AM   #13
cleex024
Neil
Right I understand that your oil temps exceed your thermostat full opening point however if you start cooling sooner then you might not reach those temps as you might be on the straight away to start cooling again
      04-23-2013, 11:57 AM   #14
cleex024
Also I've been doing the bypass one where you just put the spring on the other side of the valve and just did 4 pulls to 130 and damn temps just won't go up pay 210... but when I'm just sitting here idling for about 10 minutes my temps get up to about 222... ambient temp is 53 and cloudy
It obviously works but I wouldn't want to drive on the interstate with temps that low cruising as I'm sure I'm going to lose mpg plus I'm pretty sure bmw engineered the engine oil to run at 235.
It's not that our engines run hot is just that bmw made it that way. .. all engines produce pretty much the same amount of heat relative to power produced.
Anyhow I'm going to cut the spring little by little till I get the thing opening right where I want it as that is the only thing really that determines when the valve opens and close
      04-23-2013, 12:58 PM   #15
cleex024
So I've done more cruising and my temps stay at 200 degrees lol...way too low in my opinion.
Oh and this is on my factory oil cooler haven't put in my er yet
      04-23-2013, 01:15 PM   #16
N8N
N8N's Avatar
Drives: 2009 E92 335i 6MT
Personally I like to see oil temps over 100C/212F but not much over. This keeps any moisture out of the oil. So 220-230 = good
      04-23-2013, 01:16 PM   #17
cleex024
Yup 220 is going to be the magic number I'm going to shoot for
      12-12-2013, 12:32 PM   #18
Red_Bean_Bun
Drives: E92
So how much did you cut ?
      12-23-2013, 08:12 PM   #19
Julian2485
Drives: Black lci e90 335 xdrive
Oil temps
So did u ever get your temps to stay around 220 I have a 335xi 6 spd and am planning on retrofitting the oem oil cooler which I have all the parts already. So please give whatever info you have on keeping the temps around 220 thanks in advance
      12-23-2013, 08:43 PM   #20
Astephens94
Slightly modified...
Astephens94's Avatar
Drives: 2007 335i
2007 335i  [6.00]
I did the BMS T-stat replacement back in the fall. I drove from Philadelphia to New York today (approximately 130 miles) in 60 degree weather + rain. 70-75mph. Temperatures were consistently 200 - 205 F
I typically see oil temperatures 15-20 degrees lower compared to the regular T-stat in temperatures above 75 degrees (so 220-225)
Very happy with this $59 investment.
      12-23-2013, 09:39 PM   #21
taylors335
taylors335's Avatar
Drives: Space Grey 08 335i
2008 335i  [7.00]
i pulled my T-stat out completely , have no issues
Reply
e90post
