335i at dealer with alpina tcu flash
04-23-2013, 11:20 AM | #1 |
Rep 447
So my car is at BMW right now being diagnosed. My AT gear selector has the issue where I cant up/down shit with it. BMW whats to update me DME and everything, will this over wright my aplina TCU flash? or will they encounter any issues because of coding or the flash done to the car?
2008 Bsm E92 335i - FBO -E85--------Sold
2014 BSM 335i Msport - Stock |
04-23-2013, 11:26 AM | #2 |
Retired e90post Member
135
Rep 3,038
did you pop the trim off to see if there were any crimped wires under there? that's usually the cause of the issue. if they do update your ecu the flash will be back to stock.
04-23-2013, 11:29 AM | #3 |
Rep 1,153
This could potentially be a problem being there is different software in the TCU. I wouldn't be surprised if they flag your car when they see this. In for results.
2016 340i xdrive
2009 335i |
04-23-2013, 12:39 PM | #6 |
Rep 1,137
cut wire/wires is usually the culprit and very common problem
2008 335i coupe AW 6AT, RB Turbos, PROcede 2.5 V5, Alpina Flash, Injen Intake, VK MW DP . Helix IC, Vishnu PnP Meth(M10 nozzel), M3 sides, OEM Aero Lip, VMR V710 Midnight Blue, LUX H8, HID Fogs, M3 front bits, D2 Coilovers, Whiteline Rear Bushing inserts, Custom M3 Steering Wheel, Cyba scoops, M2 Performance Exhaust |
04-23-2013, 01:28 PM | #7 |
NeedsMoarBoost
42
Rep 527
pretty sure they'll just flash it to stock config just fine.. if problem is still present they will look at wires...
typical Dealership bullsh;t way of troubleshooting... do this if that doesn't work do this if that doesn't work do that if that doesn't work blame the intake...
08 135i 6m - 12.1@120.2 2.0 60ft - JB4/Meth - SOLD
09 335i e92 Mtech - RB FBO |
04-23-2013, 01:31 PM | #8 | |
Rep 447
04-23-2013, 03:07 PM | #9 |
Rep 447
dealer voided warrenty and flaged car trying to blame my "intercooler and charge pipe" for my oil filter housing gasket, valve cover gasket, and oil pan gasket leaks
lawyer is informed will continue to update... all i went in for was my shifter and battery recall fuck BMW crooks
04-23-2013, 03:15 PM | #10 |
Rep 213
wow, so they flagged you when they weren't even looking at the issue you went in for? or did you have them look at the leaks while you were there and they try to blame the IC?
04-23-2013, 03:43 PM | #11 |
Rep 447
called and asked me if i would like those leaks fixed i said sure why not, increased value of my claim. so they had to send someone out for approval of the fixes. and denied it based on what he saw when he opened my hood.
previous info in there system about the oil filter housing gasket which they claimed was "seeping" not enough to replace under warranty. I guess now were its "leaking" now a few x,000 miles later they decide to deny. based on unrelated parts or problems.
04-23-2013, 03:54 PM | #13 |
Rep 447
intercooler and charge pipe/bov were only mods on going into dealer. all else stock took everything off
04-23-2013, 04:28 PM | #15 |
Rep 1,948
Its all up to the dealers. I have always taken my car fully modded. They have never hassled me regarding warranty. I mean, my car was fully modified with down pipes, procede, charge pipe, FMIC etc and they replaced the engine block due to it hitting the sub frame. All covered under warranty.
On the other hand, another dealer gave me shit for complaining the car had no oil cooler when I just bought it. Basically, the head tech said that it drove just fine and didn't require one. I told them I specifically wanted a model with oil cooler and it was too late as I had waited for my car 3 months before I received it. Long end of it, BMW and that dealer said no, I didn't need it. That was in the first 1000miles of the car and it was stock. Never went back there again! OP, good luck though. |
04-23-2013, 07:07 PM | #17 |
Rep 104
They did what they are meant to. Just Call BMW NA and tell them that the seep was noted back on a previous work order and was not corrected. And that you was informed it was not covered. Since then you replaced the FMIC and now they are saying same leak is not covered because of the part. When they never had an intention of covering it.
My question is why would you go to the dealer if the car has warranty with any mods on. |
