new error codes in my cobb
04-25-2013, 05:30 PM | #1 |
Rep 307
hellow,
i just checked the errors on my car and i found many codes, i searched in every where even in google but i didnt find anything did someone had them before ? here they are H0DA1 H0D98 H0d9C H0DA5 H0DAE H0DA8 H0D9E H0D9D H0DA0 H0DB4 |
04-25-2013, 05:51 PM | #2 |
Rep 7,377
H are history codes. just search for them without it .
04-25-2013, 06:39 PM | #3 |
Rep 518
Do you happen to have the Alpina flash for your trans?
04-25-2013, 07:17 PM | #4 |
Rep 645
I have the tranny flash (im not the op) my codes are as follows after seeing these posted i checked.
P2AAF H0DA8 HODA5 HOD95 H0DA0 HODBO H2DC3 H0D94 H2F4C H0DA9 HODA6 couple of them are in both but mostly there different codes. |
05-21-2013, 05:08 PM | #8 |
Rep 959
Drives: 08' M5, '09 335i, '18 M3 MT
Same Codes with Alpina Flash
Verde Mantis Green M3 F80 Manual - Motor Journalist from Germany and BMW Genius |
05-21-2013, 10:57 PM | #9 |
Rep 2,301
0DA2 is a gear control code, so I'm guessing all these are codes indicating gear control malfunctions. BAD NEWS. I would flash back to the stock TCU software, if I were you guys.
'07 335I w/ Mods
'13 X1 Stock '11 X3 K&N |
05-22-2013, 09:59 AM | #10 | |
Rep 436
I wonder why this topic doesn't come up more with more Alpina folks. Is it because others have not scanned for codes or simply don't have these codes? Or is it an installer issue? I was scheduled to have my Alpina flash done yesterday. My shop said my car did not accept the flash. I would like to try this flash. I'm not sure how I feel about having codes come about from the flash. Or if the codes are a result from something else. Interesting. |
05-22-2013, 10:04 AM | #11 |
Rep 7,377
When you reprogram the tcu you have to delete the tranny codes and engines codes with inpa....
05-22-2013, 12:46 PM | #12 |
Rep 436
What does inpa stand for? Can I clear it with my Cobb AP? I'm assuming by deleting the tranny and engine codes they will not come back unless the car is flashed back to OEM. Thanks for the info.
05-22-2013, 01:01 PM | #13 |
Freude am fahren
71
Rep 1,968
Drives: E90 N54
I have TCU flash by @cn555ic and I have no such codes on my AP
Cobb E40 PROtune by Jake@PTF/RR catless DPs/aFe DCI/ETS 5" FMIC/ER CP/Forge DVs/Alpina B3 TCU flash/BMW Perf. Exhaust./BMW Performance Style 313s/M-Tech Rear
05-22-2013, 01:06 PM | #14 |
Rep 7,377
Thats because he cleared them after the flash. Same procedure i do when i flash other cars per DIY.
Inpa is a software that allows you to get into all the cars module. Search for the diy ... Or google it
05-22-2013, 01:09 PM | #15 | |
Freude am fahren
71
Rep 1,968
Drives: E90 N54
EDIT: Not sure if you mean the last sentence for the OP...
08-01-2013, 08:40 PM | #17 |
Rep 1,656
I have same codes after TCU alpine B3 falsh. So they must be regular TCU codes thrown during alpine flash will clear them with Cobb AP.
nickname"BAD 3",MHD E85 tune,RennArt catback non-resonated exhaust,VRSF Downpipes, VRSF 7"FMIC,VRSF stock side inlets,SSQV BOV,ECS CP,M-performance alcantara steering,retrofit M3 paddle shifters,Alpina B3 tranny flash,AFE power seal CAI,LED angels,ST Coilovers,M3 upper/lower control arms,E93 M3 Front Swaybar ,235/35/19x9 ,275/30/19x9.5. M sport bumpers, CF diffuser. When in doubt..flat out.
