Engine Malfunction after BMS DCI install
05-21-2013, 11:34 PM | #1 |
Rep 439
I received and installed my DCI from BMS today ('07 e92 335i) according to the instructions that they provide on their support page.
I've double-checked the connections (especially the rear intake) and everything seems to be fine. If I drive the car it doesn't feel like it's getting full power and if I take it to 5k or so in fifth gear the Engine Malfunction light comes on. I don't get a CEL. I'm looking for any recommendation on where to look. Right now I'm fairly clueless about what's wrong. Can I run an OBD-II scanner on the car and pull any potentially "hidden" codes, or does that require more than just an OBD scanner? This is my first "performance" mod. No tune, etc. |
05-22-2013, 12:09 AM | #3 |
Rep 439
05-22-2013, 12:12 AM | #4 |
Rep 6,136
05-22-2013, 08:49 AM | #7 | |
Jedi samurai ninja turtle
621
Rep 3,021
Drives: X3 M40i 2018
05-22-2013, 09:52 AM | #8 |
Rep 6,136
05-22-2013, 10:11 AM | #9 | |
Rep 439
I've noticed that I'm not really getting the sound that I would expect to get out of the intakes. My e36 m3 definitely makes more noise when giving it throttle and it sucks air up than these. Just something I thought was weird when I was driving. It could be because of reduced power, of course. But it was still strangely quiet to me. |
05-22-2013, 10:31 AM | #10 |
Rep 439
I just checked that line again and it's connected at all 3 points, in the front near where the stock box was, in the rear towards the driver-side strut tower and the line going into the middle of the aforementioned line (from the right) is also secured.
05-22-2013, 10:47 AM | #11 |
Rep 6,136
Ok. Start your car, let it run for about 10 seconds, shut it off. Go over to the hard plastic vac line that goes over the front DCI cone and disconnect it. If you hear air hissing for a second out of it, you are good. If you hear no hissing, you have a vacuum leak somewhere.
05-22-2013, 10:59 AM | #12 | |
Rep 439
I wanted to be sure that I let it run long enough so I started her up and let her run for 1-2 minutes before shutting it off and doing the same but still no hissing sound. Now do I just start spraying carb cleaner like a mad man or is there a better way to test for a vac leak? Shops here charge $150 or so to use smoke machines. |
05-22-2013, 11:04 AM | #13 | |
Rep 6,136
05-22-2013, 11:35 AM | #14 | |
Rep 439
Edit: I tried to check my lines but they're not really rubber. I don't know what you'd call the material, though but it has a woven texture. Last edited by CarEnthused; 05-22-2013 at 11:43 AM.. |
05-22-2013, 12:08 PM | #15 | |
Rep 6,136
05-22-2013, 05:24 PM | #16 |
Rep 439
The lines look old but when I spray them down with TB cleaner my idle doesn't change at all.
I pulled off the connector by the first intake and there's some vacuum when the car is running but it seems weak. I say that but I don't have anything to compare that to. Is there a diagram somewhere online of the vacuum lines on this car? |
05-23-2013, 12:51 AM | #19 | |
Rep 439
As far as the DV's go, I've checked those. They're still tight and locked and I sprayed TB cleaner on them somewhat heavily to make sure those weren't where the leaks were coming from. I'm still wondering if the lack of any significant audible "whooshing" from the intakes is a bad sign or if that's because of the lack significant vacuum pressure preventing additional air from being pulled into the cones. I don't know if that even makes since so if I could get someones' opinion on that, I would appreciate it. |
05-23-2013, 12:32 PM | #20 |
Rep 439
I took her to an independent shop and they were able to pull 4 codes that I wasn't. In addition they ran a smoke test for me and didn't find any vacuum leaks.
I'm going to start searching regarding these codes but this is what they pulled: 29F3 - Fuel Low Pressure Sensor -Keeps coming back 2A20 - Fuel Low Pressure System - Cleared and didn't come back 2AAF - Fuel pump plausability - Cleared and didn't come back 30FF - Turbocharger boost pressure too low -Cleared and didn't come back. |
05-23-2013, 12:51 PM | #21 | |
3442
Rep 79,211
30FF would have been boost leak, it won't appear until you go WOT (Wide open throttle) underboosting (Not meeting boost target) for 3-4 seconds. |
05-23-2013, 12:53 PM | #22 | |
Rep 439
Could the LPFP failing also cause odd idling? EDIT: Can anyone help me find the part # for the LPFP and the Low Pressure Fuel Sensor. I've been checking. EDIT AGAIN: Just found them: LPFP: 16 14 7 163 298 Low Fuel Pressure Sensor: 13 53 7 614 317 It would be nice if dealers didn't throw a fit about giving me the part number. Last edited by CarEnthused; 05-23-2013 at 01:04 PM.. |
