how much power can the AT hold?
05-23-2013, 01:28 PM | #1 |
Rep 189
Hi Guys,
I have all bolt ons except intercooler which ill put soon. Is it true that only this is already too much for the AT? No way I should add meth, or RB's right? Thanks Dan |
05-23-2013, 01:33 PM | #2 |
Rep 7,377
not true
05-23-2013, 03:43 PM | #4 |
Rep 40
this trans. amazes me. i had to modify my vet trans to hold slightly over 400hp...that be said i would still do the alpine b5(i think) main for the quicker shift instead of clutches and bands slowly(sliding) in to gear changes...less heat build up which we all know is detrimental to autos.
05-23-2013, 03:52 PM | #6 |
Rep 799
Drives: 08 335 silverback
510whp/500tq on mustang...auto tranny
FBO...METH...BIG TWINS
05-23-2013, 04:20 PM | #7 |
Rep 2,387
One thing that people miss here is there are very few cars with high TQ (maybe none) that have run the Alpina flash from BEFORE they had all that TQ. So we really have zero data on what it will hold up to with a proper flash for mods, done prior to cranking all that high TQ through it.
05-23-2013, 04:28 PM | #8 | |
Rep 2,172
05-23-2013, 04:40 PM | #9 | |
Rep 6,478
E88 N54 Alpinweiss/Coral Red/Motiv HTA 3586r Tial .82AR/Other stuff...652WHP
F30 N55 XDrive EBII |
05-23-2013, 04:55 PM | #10 | |
Rep 2,387
Let's see someone take a fresh (stock) tranny in good condition with nothing but the flash and run it 500+ TQ see what happens. |
05-23-2013, 07:56 PM | #11 |
Rep 2,172
Well, I'm not sure what point you're trying to make. We know that it makes the trans hold more power with less slip, so why would it be any different for a new trans? If anything it would make it last longer.
05-23-2013, 09:36 PM | #12 |
DIYER
614
Rep 5,521
I am above 500/500 and still holding great, no flash though....car is to old I also have upgraded tranny mounts if that matters.
JB4 G5, Stage 3 LPFP, Stage 2 MOTIV PI, VM 6466 ST, Custom OCC W/ SS lines, ER FMIC, ER CP W/HKS BOV, M3 control arms, M3 guide rods, M3 upper links, M3 front & rear sway-bars, HPA rear toe arms, Wavetrac LSD, HPF Gen 2, DEFIV kit, KW clubsport, Delrin solid SF bushings, stoptech rotors, Rogue Tranny Mounts, 1M bumper, M3 CF hood, M3 fenders, M3 OEM sideskirts, Mtech rear bumper, CSL trunk, MORR VS8.2 rims 245/295
05-23-2013, 11:00 PM | #13 |
Rep 2,172
05-23-2013, 11:29 PM | #15 |
Rep 290
05-23-2013, 11:58 PM | #16 |
DIYER
614
Rep 5,521
That's what I thought too?
05-24-2013, 12:30 AM | #17 | |
Rep 2,172
Find a cheap transmission local on car-part.com. Drop the pan, disconnect the MCM and drop the valve body. Replace with post 03/07. Recommend installing ZIPKIT prior to installation. Once installed, flash with Alpina B3 transmission flash. Rob, this is what the doctor ordered brother. You should DIY this when you do the swap. |
05-24-2013, 05:19 AM | #18 | |
Rep 2,387
Unflashed stock trans + high TQ = bad, lots of wear/damage on internal components leading to possible eventual failure, many cases of this Flashing this type of abused trans AFTER lots of TQ put through it, no conclusions can be drawn as to flash mitigating failures. Because the trans has been subjected to prolonged high TQ levels and may be damaged already. However, flashing VIRGIN trans and THEN running high TQ through it, we have ZERO data on. It MAY mitigate failures. Flash has only been available couple of months tops whereas most high TQ AT cars have been high TQ for longer time than that (like Terry's). Jeez. All I am saying is we do not know anything yet about how the Alpina flash does on a VIRGIN trans running high TQ. All other trans have been thrashed W/O flash, then flashed. edit: Also as far as I know Alpina did not see the need to beef up 6HP21 internals on the B3, they are usually pretty crazy about hardware. Last edited by ajsalida; 05-24-2013 at 05:24 AM.. |
05-24-2013, 04:12 PM | #19 | |
Rep 565
08 E90 335i AT RB Turbos -NX Wet Kit - Chiplogic Flash or Procede V5- M3 Diff - AE Exhaust- Forge Dv's - Helix Intercooler - AR DP's - P3 Boost Gauge - Vishnu Meth- Stett Chargepipe and CAI
09 C63 |
05-24-2013, 04:18 PM | #20 | |
Rep 2,013
05-24-2013, 08:24 PM | #21 | ||
Rep 645
05-25-2013, 12:56 AM | #22 |
Rep 1,153
Can you elaborate? How much wtq are you putting down? I would love to upgrade to a set of RBs but refuse to until there is a viable solution for the AT.
2016 340i xdrive
2009 335i |
