E90Post
The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > First set of logs.
Reply
      05-24-2013, 11:39 PM   #1
///Macht
///Macht's Avatar
19
Drives: '18 ZCP Mexico Blue M3
2007 BMW 335i  [10.00]
First set of logs.
Logged my first WOT pulls tonight in preparation for a PTF e-Tune, and I'd like to know what I'm looking at. I'm running stage 1 aggressive with a BMS dual cone intake and a 25% E85/93 blend (4.000 gallons exactly). The logs themselves are hieroglyphics to me, so how do they look?
      05-24-2013, 11:48 PM   #2
Tommeh
Drives: 96 BMW M3 & 16 GMC Canyon
What gear where you in? Looks like you where in second gear or 1st because the logs are so short. You need to do some 4th gear wot pulls to actually see numbers.
      05-24-2013, 11:54 PM   #3
Ænema
Everything looks good to me
Give this thread a read in order to get a better understanding of the major channels and what to look for in a log http://www.e90post.com/forums/showthread.php?t=696472
"I'm not surprised you get along well with all the other neighbours. If you put fifty children with Down's syndrome in a room there is going to be a lot of hugging." David Thorne
      05-24-2013, 11:58 PM   #4
///Macht
///Macht's Avatar
19
Was in 3rd gear. Pulled from 2000 RPM until around 6000 and let off.
      05-25-2013, 12:29 AM   #5
///Macht
///Macht's Avatar
19
So, from what I've read in the past about stock to stage 1 gains, I should expect a 70whp bump over stock (running stage 1 aggressive, 25% E85/93 blend). Using the logs I attached in the original post, I'm seeing 319whp for datalogs three and four, and 298whp for datalog five on Virtual Dyno. Is this normal? I've just stumbled upon Virtual Dyno, so I'm not sure whether it's accurate or not, so I'm just curious.
      05-25-2013, 12:46 AM   #6
Ænema
70whp gain from just a stage 1 tune isn't really likely... more like ~50whp.
As far as how accurate is VD? Well, that depends on you. Weight, tire size, road conditions, traction and a number of other things all play a part... but if it's all on the up and up then it can be fairly accurate.
Keep in mind the point isn't just to get a set of numbers, it's a tool to track progress. If you're consistantly seeing 300whp then make a change and start seeing 330whp(all things equal) then you're going the right way.
      05-25-2013, 12:50 AM   #7
///Macht
///Macht's Avatar
19
Took a longer look at my first log, and noticed at lower RPM, requested boost and actual boost aren't very near to each other, but at higher RPM they even out with each other. Is this normal?
      05-25-2013, 01:04 AM   #8
Ænema
Yep, it takes time/RPMs for the turbos to spool enough air for actual boost to hit requested.
      05-25-2013, 11:32 PM   #9
cwarren
cwarren's Avatar
82
Drives: 08 e92
^ agree took a sec to decipher log but all looks great at least in first log didn't look at the others .
ptf MHD E85 /Hexon rr550 turbo's/PRE custom intakes/CP / bms dp's/hfs4 / er fmic/PSS/spec stage 2+/kwv2/steveAZ stage 3 lpfp /m3 control arms/powerflex black/MF LSD /fuel it port injection
      05-25-2013, 11:39 PM   #10
///Macht
///Macht's Avatar
19
I did a few more pulls tonight. Feel free to take a look! Datalog 6 was a 4th gear pull for shits and giggles. Datalog 7 was a 3rd gear pull, but auto-shifted around 6600 RPM. 8 and 9 were both 3rd gear pulls.
Using Virtual Dyno, datalog 6 showed 340whp (4th gear), datalog 7 showed 407whp, datalog 8 showed 338whp, and datalog 9 showed 346whp. A considerable increase over last night.
      05-26-2013, 12:15 AM   #11
Ænema
All the logs looked really good.
      05-26-2013, 07:33 PM   #12
///Macht
///Macht's Avatar
19
Logged the first iteration of my custom tune for stage 1 aggressive and an E85/93 blend. Clocked in at around 384whp running only the AccessPORT and a DCI. Will include incremental updates as we go.
Reply
e90post
