F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Adaptive Headlights: Re-enable? Help!
GetBMWParts
      05-26-2013, 10:54 AM   #1
legaleye3000
Drives: 2014 328i; 2015 X3
If I accidentally disabled my adaptive headlights when disabling the fogs-on-when-turning, how do I re-enable the adaptive headlights? Thanks.
      05-26-2013, 12:36 PM   #2
kon
Singapore
21
Drives: F30 310i > G20 310i
VO coding your fembody ecu will restore everything back to default (assuming you never actually changed any VO in the fa file)
      05-26-2013, 02:06 PM   #3
legaleye3000
The only thing I changed via vo coding was to change my com box from 6nh to 6nk (or vice versa).
      05-26-2013, 08:00 PM   #4
kon
Singapore
21
Then you can just vo code FEMBODY, it will restore everything back to factory settings
      05-26-2013, 08:05 PM   #5
legaleye3000
Kon- I'm looking to start from scratch and make my whole car as if I just bought it. Do I just open esys, activate FA, and right click on each ecu and click code? Will that return everything to stock? Thank you!
      05-26-2013, 08:49 PM   #6
kon
Singapore
21
If you want it absolutely stock, you need to edit your FA file to restore 6NK to 6NH, then VO code by right clicking the top of the SVT file and "code" - as adviced by Shawn... but BECAREFUL since coding the whole car might take a long time, and your car battery may not be able to last through the session.
So it might be better to just "code" the ECU you have alterered one at a time
(preferably with engine running to make sure there is constant electrocity supply to the car)
      06-03-2013, 09:07 AM   #7
pcbrew
pcbrew's Avatar
29
Drives: 2012 335i 6MT
Is this the full adaptive headlight option with beam-shaping & beam-splitting they have in Europe?
I did some very basic coding when I first got my car (2012 model) but would be interested to enable this, if possible. I did a search in the coding thread but did not find anything definitive so appreciate any feedback.
2012 F30 335i 6MT - Imperial Blue w/Everest Gray: Sport, Adaptive M, Premium, Tech & Parking Pkgs, Assist, Apps
f30post
