injector replacement procedure update
05-27-2013, 12:00 PM | #1 |
Stupid Idiot
134
Rep 827
I've been meaning to post this, but keep forgetting. BMW has (again) changed their internal policy on N54 injector replacement with the new part # 13 53 8 616 079 injectors. Previously, it was stated that if any of these new injectors (index "11" or higher) were installed on an engine, that all injectors needed to be replaced with these same injectors.
Now, BMW has changed their recommendation. Dealers are now being instructed that the new 13 53 8 616 079/ "11" index injectors can be installed on an engine with the older style ("10" or lower) injectors, as long as they are on different banks (IE. 1-3 or 4-6). Meaning..... if you have a bad injector on cylinder #6, you could install the new style injectors on bank 2 (4-6) only, and leave your original injectors on bank 2 if you wish. Why BMW changed their tune on this issue, I'm not sure. If it were my car needing injectors tomorrow, I'd probably still replace all 6 with the latest and greatest -- but that's just me. Now, you do have less expensive options, though. Here is the updated information I happened to "find" : In the case of reproducible “cold start” rough engine running with corresponding misfire faults, replace all three high-pressure injectors on the bank that is faulted (1-3 or 4-6) using improved P/N 13 53 8 616 079 with index 11 or higher. For example, if the engine has a misfire on cylinder 1, replace injectors for cylinders 1-3 if those injectors are not already index 11 or higher. If the injectors on that bank are already index 11 or higher, only replace the injector on the faulty cylinder. Use P/N 13 53 8 616 079 when replacing the injector(s). IMPORTANT: Injectors with index 11 and higher have a different calibration and construction than injectors with index 10 and lower. Due to this difference, the injectors with index 11 and higher and injectors with index 10 and lower cannot be mixed on the same engine bank (i.e., cylinders 1-3 or 4-6). Once a bank of injectors is at index 11 or higher, the “bank set replacement” requirement no longer applies. For index 11 injector failures, only replace the failed injector. Hope this clears it up........
05-27-2013, 12:14 PM | #2 |
Rep 715
Old news ... one day old anyway
But good to have this info for sure , thanks
Vargas S2 turbos|VAC S3 Cylinder head|RR DPs|RR MPs|Supersprint X pipe|Remus Quad Sport mufflers|aFe Stage 2 Si with scoops|Forge DVs|ER CP|BMS meth elbow|Aquamist HFS-4|Walbro 450 E85 LPFP|AA FMIC|BMS OCC|MHD|P3 Boost Gauge|Ohlins Road & Track + camberplates|M3 sways F/R+ Ground control endlinks|Vorsteiner v303 19"|Michelin PS2 sport|Quaife LSD|Vorsteiner V35 CF hood|CF CLS trunk|Duke Dynamics quad diffusor
05-27-2013, 12:27 PM | #3 | |
Stupid Idiot
134
Rep 827
I had this info the day it was released, but kept forgetting to post it. I don't see any other threads devoted to this new info, though, so hopefully it helps someone.
05-27-2013, 12:33 PM | #4 |
Rep 715
Yes , me
05-28-2013, 01:49 PM | #7 |
Rep 4,393
Wow that's good news. If I can't solve my misfire issues at least now I can replace all my bank 2 and not have to do all 6
< Click picture for photoshoot
E90 335i xDrive 6spd, Nav, Prem, Cold Weather, & Sports package - Msport Conversion Mods: JB4 + MHD, Doc Race ST, Pure 6266, AD-Eng PI/Mounts, Fuel-It st. 3, Custom Exhaust, Tuned by TwistedTuning More Pictures: Build Thread /// 683AWHP/675AWTQ |
