06-01-2013, 09:56 PM | #1 |
Rep 941
M Performance Suspension
I finally managed to get this kit on the car. If you're dissatisfied with your F30 suspension then I thoroughly recommend this one. Its been reviewed to death on the suspension forum, but to reiterate what most are saying, the car feels much more planted. That general feeling of floatiness is gone. It now feels much more like my e92 on sport suspension, but taken up a notch or two. Ride is also still pretty compliant, comfortable enough when cruising around, but point the car at some corners and it really eats them up. Overall, I'm satisfied, its what I expected and more.
If you're considering this just be aware that the kit has not yet been approved by BMW Aus, so you will need to source it elsewhere and find an independent specialist to do the install. There's probably also some warranty implications in that as well. Also be aware that the front sway bar does not simply pop out (like the E9x). You need to drop the front subframe to do the swap (considerably more work). I may take some photos later. The car sits higher than it did previously (it was on H&R sport springs before) but I actually prefer how it looks now. It's got a nice aggressive stance without looking retarded. |
06-02-2013, 08:40 PM | #4 | |
Rep 1,549
06-02-2013, 09:43 PM | #5 |
Rep 941
Thanks mate. I think if you get the US prices for the parts, factor in shipping, import duties, exchange rate etc, its actually pretty reasonable.
Install was also pretty decent I thought. It turned out to be about 9hrs labour, so I don't think they'll be doing it again at that price. |
06-03-2013, 03:35 AM | #10 |
Rep 3,288
Drives: anything given a chance
Sway bars would help a lot with the "planted" feeling. Nice work mate. Suspension mods are underrated by most IMO but so worthwhile you usually wonder, "Why didn't I do that earlier?"
06-03-2013, 04:21 AM | #11 |
Rep 941
One day maybe
They're separate part numbers. You need the retrofit kit, the springs, and for non M sport cars, the front and rear sway bars. Working on it. M sport is 10mm lower than standard and the M performance another 10mm lower than that.... and compared to H&R sport its 10mm higher Yeah definitely. In fact it would have been much sooner but for delays with parts and later the install. I actually kicked this whole thing off back in January Totally agree about suspension mods being underrated, best mod to date for me! |
06-03-2013, 05:09 AM | #13 | |
Rep 545
btw did you not consider aftermarket options for suspension ie KW, Bilstein etc? and if so why didnt you go for them? Im running Bilstein PSS10 myself and yes the F30 really needs suspension mods and they helped heaps. |
06-03-2013, 05:20 PM | #16 | |
Rep 941
If I went aftermarket I would probably have gone with the Bilsteins with my existing H&R springs, and waited for some decent sway bar options to show up. |
