Attention: Forge DV Owners that also have a Persistant 30FF Code
06-04-2013, 08:14 PM | #1 |
Rep 1,465
Drives: 2009 BMW 335xi
I apologize first if this is common knowledge and I was just in the dark. Also I am not sure if this applies to all versions of the DVs since I know Forge has redesigned them at least once.
As the title says I had a persistent 30FF code and was unable to find the leak. I finally found a tiny leak in one of my forge dvs and assumed that I needed a rebuild kit. Well the rebuild kit arrived today (complete with redesigned piston I might add) and after I installed it, the DV still had a small leak. I messed around with it a little more and discovered that the nipple actually unscrews! (see pic below) This is the source of my leak! It looks like the threads actually had some type of sealant or thread locker on them but once that is broken the threads will leak regardless of how tight the nipple is. I added some new loctite blue and reinstalled and tightened as hard as I could without damaging the part. No more leak. It held 20 inches of vacuum for about 15 minutes while I messed around in my garage. Moral of the story: Check your forge dvs and make sure the vacuum nipple is secure. If in doubt, remove, reseal and reinstall. Hope this helps. |
06-04-2013, 10:39 PM | #3 |
442
Rep 18,331
I have the older version of the Forge DV and mine have never leaked. The nipple also is not screwed on either. I dont know why they redesigned something that worked without issues...
06-05-2013, 12:09 AM | #4 |
Rep 715
Only issue I had was sticky lube that seized the piston valve , got stuck in open...
cleaned , replaced lube and problem solved.
Vargas S2 turbos|VAC S3 Cylinder head|RR DPs|RR MPs|Supersprint X pipe|Remus Quad Sport mufflers|aFe Stage 2 Si with scoops|Forge DVs|ER CP|BMS meth elbow|Aquamist HFS-4|Walbro 450 E85 LPFP|AA FMIC|BMS OCC|MHD|P3 Boost Gauge|Ohlins Road & Track + camberplates|M3 sways F/R+ Ground control endlinks|Vorsteiner v303 19"|Michelin PS2 sport|Quaife LSD|Vorsteiner V35 CF hood|CF CLS trunk|Duke Dynamics quad diffusor
06-05-2013, 12:53 AM | #5 |
EUROPROJEKTZ
187
Rep 7,958
Drives: backwards
Thanks for the heads up! Definitely helps out the community.
LTMW|SPEEDELEMENT|EUROPROJEKTZ
#TeamStretchNPoke |
06-05-2013, 10:13 AM | #6 |
3442
Rep 79,211
Good find. You can also use teflon tape just in case you ever wanted to unscrew it again (with ease). Not sure why would but it's worth mentioning.
06-05-2013, 11:12 AM | #7 |
Rep 1,465
Yeah I wanted to use teflon tape but I didn't have any on hand and didn't feel like buying some just for this. Also, as you say, why would you want to take it back apart.
06-05-2013, 02:03 PM | #8 |
Freude am fahren
71
Rep 1,968
Drives: E90 N54
pretty sure loctite blue isn't permanent...it can be undone with hand tools.
Cobb E40 PROtune by Jake@PTF/RR catless DPs/aFe DCI/ETS 5" FMIC/ER CP/Forge DVs/Alpina B3 TCU flash/BMW Perf. Exhaust./BMW Performance Style 313s/M-Tech Rear
06-05-2013, 02:39 PM | #9 |
Rep 225
06-05-2013, 04:55 PM | #10 | |
3442
Rep 79,211
Blue is easier then the red that is for sure. |
06-05-2013, 05:02 PM | #11 | |
Rep 1,465
06-05-2013, 05:02 PM | #12 |
Rep 2,353
I've broke down my DVs (taken apart every part the screws, including that nipple) multiple times and I have not used loctite on any of the threads and I have no leaks. Mine have been holding 19 psi with no issues. No design issues as far and I am concerned. I am sure my DVs have been through more than most as I have removed all the black dye from mine, they were originally black, now they are brushed aluminium.
06-05-2013, 05:04 PM | #13 |
Rep 1,465
I believe that the vacuum nipple on my dv was not tightened correctly from the very beginning (ie from the factory). I just never thought to check this because they look like they are one piece.
06-05-2013, 06:26 PM | #14 |
Rep 3,732
Drives: BMW S1000XR
Yep, good find. I had the same problem once with the Forge DVs and my 135. I also had to replace my spring once. I loved the Forge DVs, great product, but I need to buy a set for my 335
BMWCCA member |
