7 codes
06-05-2013, 08:05 AM | #1 |
Rep 361
7 codes
this morning i started my car and it started shaking violently, then the engine light came on . so i restarted the car it wasn't shaking anymore but, the engine light stayed on, so i drove it to an Indy to read the codes and he found 7 codes
P0300 P0301 P0302 P0303 a few of them were repeated . he said the culprit could be spark plugs, coils, injectors, or the engine is leaking oil on the plugs, or the engine is sucking air somewhere other than the air intake . only mods are DCI and golf tee. the car is currently a bit over 47k . the plugs were replaced at 31k .looking at the car service history it shows at 27k i had my injectors check B13 14 10 but it does say if they were replaced or not . that's pretty much it. what do u guys think is mostly likely to be the culprit. Last edited by mcpcolas; 06-11-2013 at 11:58 AM.. |
06-05-2013, 08:26 AM | #2 |
Rep 7,377
wasnt there a description of the codes in the AP? easier to get the description for fast answer than having people first searching for the codes..
06-05-2013, 08:28 AM | #3 |
Rep 361
06-05-2013, 10:00 AM | #4 |
Rep 288
Entire bank 1 misfiring.
From what I have seen, it could be, - Primary O2 sensor - Low pressure fuel pump.
Cobb / DCI / VRSF Downpipes / VRSF 7" Intercooler / Walbro LPFP / E85
06-05-2013, 10:43 AM | #5 |
Rep 361
06-05-2013, 11:07 AM | #6 |
Rep 2,590
If its the entire bank you can rule out plugs and coils most likely. As stated it may be o2 sensor or leaky injector causing entire bank misfire.
06-05-2013, 12:43 PM | #9 |
Rep 7,377
if it does that during cold start (car left overnight) and you smell gas is injektor.
06-05-2013, 01:59 PM | #11 |
Freude am fahren
71
Rep 1,968
Drives: E90 N54
probably the primary oxygen sensor for that bank, but faulty oxygen sensors usually throw lambda codes...but you're right at the mileage where they shit the sheets. keep us posted.
Cobb E40 PROtune by Jake@PTF/RR catless DPs/aFe DCI/ETS 5" FMIC/ER CP/Forge DVs/Alpina B3 TCU flash/BMW Perf. Exhaust./BMW Performance Style 313s/M-Tech Rear
06-05-2013, 08:32 PM | #12 |
Rep 361
Can anybody post picture of the primary 02 sensor and its location for me, if its easy to get to I'll replace it tomorrow .and a part number would be appreciated.
06-05-2013, 08:54 PM | #13 |
Rep 288
You need to give more specific details of what you are experiencing so people can help.
So, you started up the car and immediately it started to misfire and threw codes. Then you cleared the codes and as soon as you started the car again and immediately you got the codes that you posted above, or after driving it, the codes appeared again? Are those the only codes you are getting? You are going to have to start trouble shooting from easier to more complex. - You can take out spark plugs and look/smell for oil or fuel on spark plugs. Troubleshoot injectors, coils, spark plugs and low pressure fuel pump/sensor before doing o2 sensor. For low pressure fuel pump, you are going to have to log and look for LPFP, should be ~60 to ~72 psi at all time. If not, it may be pump or MOST likely low fuel pressure sensor. Changing the o2 sensor is no that easy, you are going to do step 1 through 11 http://www.e90post.com/forums/showthread.php?t=104333
06-05-2013, 10:53 PM | #14 | |
Rep 361
it started shaking and the ses light came on, so i shut it off, and restated it again after i did that it wasn't shaking as violently as before but u can still feel the vibration and the ses light remained. i never cleared the codes, i drove the car to a mechanic and he was able to pull those 7 codes. and yes that all the code he was able to get all misfiring in cylinder 1,2,3,and random misfiring |
06-06-2013, 09:43 AM | #15 |
3442
Rep 79,211
Just misfire codes? Any shadow codes for fuel? Some indy shops only have generic code readers and can't read shadow codes from BMW. Those shadow codes from BMW diagnostic tools will likely have the answer we need.
I would first pull the plugs as they can tell you a lot. First thing I would do is check them for oil or gas. (They smell different so I hope you know the difference). They should be gray in color so if they are covered in black you've likely narrowed down your problem to an oil issue (valve cover gasket) or fuel issue (leaky injectors). While you are in there I would check the gap on the spark plugs. A gapping tool is like $1 at any auto parts store. It's a cheap fix to see if your spark plugs are simply worn out. Over time the gap increases. You want the gap to be 028" (0.7mm). I would clean them with carb cleaner also. Come back for more advise after you do that. That is the cheapest place to start and get answers. |
06-06-2013, 10:08 AM | #16 |
Rep 291
Question: If you have codes for vanos intake and low fuel pressure sensor. You replace the vanos and fuel sensor. Do you have to clear the faults/code for the car to run properly?
06-06-2013, 10:26 AM | #17 |
Rep 170
No, you do not. The computer will immediately detect that everything is working properly, but the codes will remain for some time. They *should* clear themselves eventually. The SES light should go off, and the codes will get a letter "H" in front of it signifying a historical code.
Carlson The Flyer
2022 X3M Competition, Brooklyn Gray, fully loaded |
06-06-2013, 10:42 AM | #18 | |
Rep 291
I had those codes on my cars after taking it to the dealership. The replaced the fuel sensor. I replaced the intake vanos. SES lights comes again after I replace the vanos. I talked to the dealership and they are telling me to bring it in and they will charge me $50 to clear the codes and it should fix the problem. I have being doubting cuz it happens the most between gear 4-6 on low rpm and low speed. Car hesitates. If I let off the gas it's fine. I continue it throws SES light and goes into limp mode. When I turn off the car and turn it back on, all is fine. |
06-06-2013, 10:54 AM | #19 | |
3442
Rep 79,211
06-06-2013, 11:06 AM | #20 | |
Rep 170
+1 to that.
Carlson The Flyer
06-06-2013, 12:54 PM | #21 | |
Rep 361
06-06-2013, 01:41 PM | #22 |
Rep 288
Delete all codes and drive the car to see what codes comes up.
If all three codes come up again, then it is not the coil. Never heard of all three coils going bad at the same time.
