06-07-2013, 08:16 PM | #1 |
Rep 2,385
Tyre shine
Any recommendations on something to apply to the tyres? I've noticed here in Texas that the tyres turn grey rather quickly.
Ideally I'm thinking a gel or similar that can be put on a cloth or soft pad and then spread on - they're 30 and 35 profile tyres, so a spray is more likely to get on the rims than anything else. Something that will spread on the tyres too, not just soak into the rag and be gone. Recommendations? |
06-07-2013, 09:10 PM | #2 |
Rep 632
i'm a huge fan of Adam's SuperVRT for tire shine.. works wonders for me
has a bit of waterproof factor, so it wont run if it gets a little wet and stays on longer than other tire shines i've used in the past also, it works well for all other exterior plastics/rubbers Last edited by finaloption; 06-07-2013 at 09:17 PM.. |
06-07-2013, 09:43 PM | #3 | |
Rep 2,385
06-08-2013, 09:41 AM | #4 |
Rep 1,053
I use maguires tire shine gel, and one of these foam applicators.
I'm sure the stuff finaloption posted works great too. I think the key is that the ones in spray bottles definitely do no work as well or last as long. You want something thicker.
Current: 2021 340xi
Retired: 2018 330xi | 2016 340i 6MT | 2013 335i 6MT | 2011 328i 6MT (N52) | 2008 335xi (N54) |
06-09-2013, 02:56 AM | #7 |
Rep 134
I think the Tuff Shine is the best option for you.
It is not so fast for applying, but this is the only semi-permanent tire coating in the world. It lasts for month! http://tufshine.com/products/tire-appearance-kit/ |
