F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Suspension | Chassis | Brakes > Give Us An F30 Sway Bar Already
proTUNING Freaks
      06-08-2013, 06:51 AM   #1
joewalton
Drives: 2015 428i Gran Coupé
We have body roll. We need a sway bar. Now.
It's a metal bar. Let's go already.
      06-08-2013, 07:51 AM   #2
Jamesons Viggen
Drives: '98 M Roadster stg 2+ S/C
I have been stalking Turner.com for it's release
'98 Dinan/RMS stage 2+(VAC cams, CES Cutring etc)
'15 Buick Regal "T"(wife)
'06 Saab 9-5 Combi 5mt (full suspension, LSD, clipped turbo etc)
      06-08-2013, 09:00 AM   #3
joewalton
Let's take it to Kickstarter.
What's it cost to make a metal bar in China? $10? It's got to be the most necessary and anticipated sway bar in automotive history, no? Is there a car with more enthusiasts out there? A car that needs body roll reduced to restore it to its prior glory more? I'm sick of waiting, not like you can just drive up to Dick's Sporting Goods and buy one in a parking lot or anything.
      06-08-2013, 09:11 AM   #4
Jamesons Viggen
Yep, materials are cheap, under $20 in steel and packaging. The money comes from the R&D and freight lol.
      06-08-2013, 09:41 AM   #5
Teemo Panda
*Bimmerpost Plasti Dip Guru*
Teemo Panda's Avatar
Drives: E53, E46-M3, E70, F25-X3
2013 BMW X3  [5.66]
Haha, you crack me up Joe!
      06-08-2013, 10:24 AM   #6
joewalton
We need a sway bar. Give it to us.
I feel a little bit better now.
      06-08-2013, 01:15 PM   #7
IM2C
IM2C's Avatar
2069
Drives: ∞ Improbability Drive
I'm sure BMW will charge $299
///| g87 | f87 Comp | g29 M40i | f97 Comp | f80 Comp | f80 | f30 | e92 | tt | S5 | e92 | 350z | e90 |
      06-09-2013, 12:03 AM   #8
AMJAM
AMJAM's Avatar
Australia
33
Drives: 2013 Alpine 328I MSport
BMW M Performance has your answer
2013 Alpine White 328I M Sport ARRIVED
      06-10-2013, 10:43 AM   #9
Jamesons Viggen
They do not offer swaybars, only that you use 704 Sport bars if your car is not a Sport/MSport to start with.
      06-10-2013, 06:12 PM   #10
AMJAM
AMJAM's Avatar
Australia
33
Ah ok I have the M Sport so I guess I already have them
      06-11-2013, 04:18 PM   #11
KK328
KK328's Avatar
14
Drives: F30 328 gracier silver
What's the difference between sport bars and sway bars?
      06-11-2013, 04:44 PM   #12
Jamesons Viggen
Same. Both swaybars, the sports bars are specific to the MSport/Sport 704 suspension and are larger in diameter.
      06-11-2013, 04:51 PM   #13
KK328
KK328's Avatar
14
Thanks
      06-20-2013, 12:48 AM   #14
M.Suka
M.Suka's Avatar
Drives: 2013 335i M Sport
These cars need sway bars asap! miss my Hotchkis sways on my E46, by far the best suspension mod ever for me.
European delivery 9-19-2012
      06-30-2013, 12:45 PM   #15
Kauro
Drives: M4
Argh, still waiting for someone to release this!!!
      06-30-2013, 08:13 PM   #16
rallybull
rallybull's Avatar
Drives: F30 335i w/PPK
Trying to understand here. I have the regular "non-sport" suspension.
  • Does that car not come with some sway bar already?
  • What would be the driving behavior if I just added a new (after market) sway bar without doing a full coilover (like M-Perf suspension)? If this itself takes care of body roll, isn't this option a bang-for-the-buck to reduce body roll without having to spend a lot on a full coil over?
  • What would be the behavior behavior if just did a full coilover (some after market one that does not come with a sway bar) without adding/changing the default sway bar ?
EDIT: I'm actually not too dissatisfied with the stock suspension in the car. I can feel some amount of road, yet it is not too harsh (so I can go over bumps pretty fast without bottoming out). However I do notice the car has body roll which I would like to address without making the suspension too harsh.
      07-01-2013, 09:16 AM   #17
utenigma
Drives: 2013 F30 335i 8SA M-Adaptive
Both standard and sport have front and rear sway bars
Std suspension front sway is 25/21.1 mm, Sport suspension front sway is 25/22.2mm
Std suspension rear sway is 12mm, Sport suspension rear sway is 13mm
Sport and M-perf suspension sways are the same
Yes, that is the purpose of a sway bar - to tie the compression of one wheel to the other which reduces roll without stiffening the straight-line suspension characteristics. Seems like a Win-Win and every car should have GIANT sway bars to eliminate all roll - not quite. Wheels should be able to articulate somewhat independently. In the case one wheel encounters a bump, the larger the sway bar the more that bump is transferred to the wheel that didn't hit the bump. So extremely stiff sway bars will cause the vehicle to judder or skip when they hit a bump. So like everything in suspension design, it's a trade off
Changing to a coil-over, changes the Spring and Strut, which alters the vehicle's compression and damping characteristics, which will (likely) make the car ride stiffer. It will also (likely) limit roll, due to higher spring rates (springs are harder to squish so car doesn't roll onto them) and (likely) lower vehicle height (car has less suspension travel so can roll less at the limit).
      07-01-2013, 09:30 AM   #18
Jamesons Viggen
Swaybars directly address body roll and are the bang for the buck suspension modifications.
      07-01-2013, 08:22 PM   #19
AMJAM
AMJAM's Avatar
Australia
33
Isn't installing sway bars on the F30 quite a serious undertaking? I am sure I read somewhere on here that someone upgraded to the m performance suspension and had to upgrade the sway bars to the m sport one and it involved quite an amount of work
      07-02-2013, 10:00 AM   #20
Jamesons Viggen
Rear sways are typically easy to install. The fronts are hard work.
I have the 704 Sport setup, won't be touching the front bar.
      07-04-2013, 10:26 PM   #21
rallybull
rallybull's Avatar
Originally Posted by utenigma View Post
[/list]
Thanks! Looks like if bmw brings out just the upgraded roll bars, it would be enough for me. Not sure if spending $3000 on the M-Perf Suspension is really worth it since I will rarely track.
      07-05-2013, 05:57 AM   #22
oceanview
oceanview's Avatar
Drives: 335i F31 RWD Autom.
[/list]Both standard and sport have front and rear sway bars
Regarding to the BMW online part catalogue, sway bars vary depending on the suspension variant (regular or M Sport) and also on the car type (F30/F31) and engine type.
Not looking at all the other models. But it seems there is quite a bunch of sway bars on the different F30/F31 models
(I hope, I did read that correctly in the online catalogue.)
335i F30 regular Suspension = Sway Bar 25mm/21.2mm Part# 31 35 6 792 118
335i F30 M Sport Suspension = Sway Bar 25mm/22.2mm Part# 31 35 6 792 119
335i F31 all Suspension = Sway Bar 25mm/22.2mm Part# 31 35 6 792 119
328i F30 regular Suspension = Sway Bar 24mm Part# 31 35 6 792 124
328i F30 M Sport Suspension = Sway Bar 24.2mm Part# 31 35 6 792 125
328i F31 all Suspension = Sway Bar 24mm Part# 31 35 6 792 124
316i F30 regular Suspension = Sway Bar 24mm Part# 31 35 6 792 111
316i F30 M Sport Suspension = Sway Bar 24.6mm Part# 31 35 6 792 112
316i F31 all Suspension = Sway Bar 24mm Part# 31 35 6 792 111
As far as I know, sway bars are made out of feather steel. I don't know if the 328i sway bar just varies in size, or if it's also another (harder) type of feather steel that's beeing used for the M Sport Suspension Sway Bar. (or will just 0.2mm more thikness make any difference? )
I don't know if the sway bar of a 335i would fit on a 328i (maybe someone else can answer that), but if so, that's maybe worth giving it a try for 328i owners complaining about body roll.
f30post
