my first virtual dyno
06-10-2013, 10:30 PM | #1 |
Rep 68
Been doing my research on this virtual dyno software seems pretty legit. Uses ur logs to estimate ur hp and torque...people from evo communities swear by it so I figured I'd give it a try
2007 335i jb4 map5 downpipes and bms dci Going to dyno my car on a real dynojet in the next few weeks so time will tell but I wanted to see what U guys think? Makes sense ?is it even close ?anyone tried this before? |
06-11-2013, 02:41 AM | #2 |
Rep 7,377
boost building seems quite slow.
06-11-2013, 08:45 AM | #4 |
Rep 68
Ya I had 2 passengers in the car ..the software asks for ur weight and ur passengers weight....and also asks for ur wheel and tire dimensions..as U can tell im still on my stock 17s definitely wheels are my next mod tho
06-11-2013, 09:33 AM | #5 |
3442
Rep 79,211
As long as as there is no wind and you are on a flat stretch of road that is repeatable it can be used.
I would suggest losing the passengers just to help with consistency. I would expect about 375WHP from those mods and 380-390 TQ. |
06-11-2013, 09:37 AM | #6 |
Some say...
239
Rep 4,296
Drives: Fresh
your not ur...pet peeve
Looks pretty sweet tho.
I have exhaust and an intake... |
06-11-2013, 09:38 AM | #7 |
Rep 1,079
There is absolutely nothing wrong with 17's! They're lighter, and tires are cheaper. I love them. Just find a set that are a little more attractive maybe.
2004 E46 M3 | Imola Red on Cinnamon | Slicktop | Manual Seats | 6spd MT |
06-11-2013, 09:41 AM | #8 |
Rep 296
Maybe I'm looking at something wrong but to me it looks as if you're running a bit too lean from about 3800rpms on... But that seems to be the deal with guys running JB.
"I live my life a quarter mile at a time. Nothing else matters: not the mortgage, not the store, not my team and all their bullshit. For those ten seconds or less, I'm free."
afe DCI/Greddy Oil Catch Can/Catless DP/ Cobb Stage 2+/Berk Axle-Back(Race)/AAW CP w BOV/H&R Springs/ ALPINA Flash/Helix FMIC/ |
06-11-2013, 11:38 AM | #9 |
Rep 7,377
thats not lean at all.
06-11-2013, 12:21 PM | #10 |
Rep 620
The Subaru guys use virtual dynos quite often. If input variables are accurate and the road used is flat and bump-free, they can be very accurate. However, just like a real dyno, it is a tool. It's best used to see how changes you made to your car in hardware or tune parameters affected your power output.
06-11-2013, 12:37 PM | #11 |
Rep 926
I would try to get the weight as CLOSEST as possible.
If the car really weighed 1842kg(4060lbs) and was on a flat road with little wind.. I would say it should be pretty accurate! I have Virtual Dynoed 3 logs with JB4, DCI, and 50% e85. All 3 runs were back to back with about 5 minutes in between to let the car cool a bit. They were all within 1-2hp and about 4-5tq. Interested to see your VD to real Dynojet comparison. There have been a few of those comparisons done and they were very very close. |
06-11-2013, 01:21 PM | #12 |
Rep 296
06-11-2013, 01:39 PM | #13 |
Rep 7,377
06-12-2013, 11:31 AM | #14 |
2097
Rep 43,350
It there may be some confusion regarding scaling. The AFR is on the left
That boost curve looks a bit unusual considering these cars usually spool hard from the get go and die off in the upper RPM range. There's also quite a bit of room to lean out in mid-upper rpm range. This is generally why I prefer flash tunes, you have quite a bit more control over the adjustments necessary on your vehicle to make the most power consistently. |
06-12-2013, 11:39 AM | #15 |
3442
Rep 79,211
The only area that is lean is anything under 3200 RPM.
11:1 AFR on a DI car is over-kill but safe. 11.5-12.1 AFR is what I'd hope to have in an ideal world for this platform. |
06-12-2013, 12:30 PM | #16 | |
Rep 546
These are 2 back to back pulls very consistent car feels super strong. I am running JB4 G5 with Cobb back-end flash. I use to have a stutter between 3k-4k just on Cobb and PTF tune nothing against Cobb It got me into the high 11's at the 1/4 mile track but Jb4 back end flash fixed some nuances that I kept having i no longer throw codes going from 4th to 5th anymore and 5th gear felt like crap pulling in the higher RPM. I am very happy I went JB4 back end flash. I am not sure how accurate this is but car feels beastly. |
06-12-2013, 01:29 PM | #17 | |
Rep 1,071
very nice
FFTEC 6466 Gen2, MHD Flash Tuned by Wedge, BMS PI Kit, FUEL-IT Stg 3 pump, HALTECH PS-1000, MFactory LSD w/lock down brace, ECS Trailing Arms, M3 control arms, M3 brace, DGR Coilovers, N20 tmap sensor, BMS OCC, VRSF exhaust w/4" tips, VRSF CP, Tial BOV. BigTom FMIC, Msport front & rear, m3 sides skirts.
06-12-2013, 08:56 PM | #19 |
Rep 15
Im on my way to try it to but what if i have a e90 335xi with sport package and staggered wheels... Witch tire diameter will i be entering in the VD ?? The 225/40/18 or the 255/35/18 ?? Thx everyone
06-12-2013, 10:08 PM | #20 |
Rep 6,631
Your tire diameter should be 25.03.
E90 LCI N54 6AT
07-26-2013, 07:04 AM | #22 |
Rep 229
Drives: 2013 335is E93
Here's mine.
