F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Coding List
Studio RSR
      06-11-2013, 09:24 AM   #1
vern
Drives: 2012 F30 335i Sport 2006 X3
Coding List
Is there a complete Coding List for what can be coded in the 2012 BMW 335i F30 Sport Line? Not a cheat sheet a ListTIA
cheers
vern
      06-12-2013, 06:40 AM   #2
vern
cheers
vern
bump
      06-12-2013, 07:09 AM   #3
rich1068
has left the building
Drives: F30 330d M Sport
Two threads below this one.
      06-12-2013, 08:09 AM   #4
vern
Rich I'm not looking for a "cheat sheet ". Just maybe you should re read the OP.
Thank you any way
cheers
vern
      06-12-2013, 10:02 AM   #5
rich1068
No problem vern. And I re-read the OP as you suggested but I don't really see much of a difference between a 'Coding List' and what others have termed cheat sheets.
I think the Google docs one is about as complete as you'll get, though it still appears to be missing some items.
      06-12-2013, 10:10 AM   #6
vern
I think the Google docs one is about as complete as you'll get, though it still appears to be incomplete.
The list I'm talking about was put up by dreamcar awhile ago and I just can't find it to make a copy.
cheers
vern
      06-12-2013, 10:49 AM   #7
Frogman
Drives: 2012 F30 328i
cheers
vern
You've asked this question on 2 other threads already. Here's my third reply...
Enclosed is a checklist I created for use when coding others F30's. It contains the most common things to code on an F30.
I have a corresponding detail sheet that lists the entries (ECU / section / variable) to change for each of the items along with notes.
The detail list also contains the many uncommon things that didn't make the checklist.
      06-12-2013, 11:09 AM   #8
vern
Thumbs up
Thank you very very much thats the list that I have been looking for. Sometimes as you well know you have to post more than once to get the reply that your looking for Thanks again
cheers
vern
      06-12-2013, 11:34 AM   #9
pcbrew
pcbrew's Avatar
29
Drives: 2012 335i 6MT
I would be interested in this detail. Would you mind sharing?
2012 F30 335i 6MT - Imperial Blue w/Everest Gray: Sport, Adaptive M, Premium, Tech & Parking Pkgs, Assist, Apps
      06-12-2013, 12:40 PM   #10
vern
Thumbs up
Just click on -F30 coding sheet summary- post #7 to me. Good luck
cheers
vern
      06-12-2013, 01:13 PM   #11
Frogman
I was trying to keep the number of coding sheets out there to a minimum (there are at least 3 now), but other people that I have sent mine to seem to like it, so I'll post it here and we'll see what happens.
These .pdfs are just prints from an excel spreadsheet. If you think you will be adding/updating this list, PM me and I'll send you a copy.
      06-12-2013, 03:02 PM   #12
rich1068
Great stuff Frogman.
And a tip of the hat to vern too
      06-12-2013, 10:08 PM   #13
Steve33
Steve33's Avatar
Drives: 2018 SQ5
I've been looking for this, thanks! A google doc would be good since your list is actually the useful/common stuff.
      06-13-2013, 01:34 PM   #14
vern
Thank you sir
cheers
vern
      06-13-2013, 01:48 PM   #15
SergioK
Drives: F30 328i
Can you point to the module, etc for #9, "Emergency Stop Signal"?
      06-13-2013, 04:19 PM   #16
Frogman
It's in the detail sheet. The numbers in the detail sheet match the numbers in the summary.
But, for reference, it's: FEM_BODY / 3060 / ESS_AKTIVIEBARER_AUSGANG
change it from flachenvergroesserun to bremslicht_blinkend
      06-14-2013, 02:16 AM   #17
rich1068
This is where they flash under extreme braking I assume?
      06-14-2013, 08:17 AM   #18
Frogman
Correct.
      06-14-2013, 11:42 AM   #19
SergioK
Drives: F30 328i
Thank you!
f30post
