Can this be permanetly removed?
06-14-2013, 10:41 PM | #1 |
DIYER
614
Rep 5,521
Can the reinforcement plate be permanently removed? My exhaust is hitting this making a rattle (exhaust has been modified slightly).
Plate I am referring to (mine is black)
JB4 G5, Stage 3 LPFP, Stage 2 MOTIV PI, VM 6466 ST, Custom OCC W/ SS lines, ER FMIC, ER CP W/HKS BOV, M3 control arms, M3 guide rods, M3 upper links, M3 front & rear sway-bars, HPA rear toe arms, Wavetrac LSD, HPF Gen 2, DEFIV kit, KW clubsport, Delrin solid SF bushings, stoptech rotors, Rogue Tranny Mounts, 1M bumper, M3 CF hood, M3 fenders, M3 OEM sideskirts, Mtech rear bumper, CSL trunk, MORR VS8.2 rims 245/295
06-14-2013, 11:29 PM | #4 |
DIYER
614
Rep 5,521
It was a "booger on the weld hitting the other pipe, fixing it as we speak.
06-15-2013, 12:53 AM | #5 |
Rep 719
My 09 xi has this plate? Are you sure yours doesnt? I drove around without the plate for a week while I waited for some nylon spacers to drop the plate down 1/2 an inch. My plate was hitting my exhaust due to a mod as well. No problems with the car while it was off but I chose to put it back on
ASE master tech (many moons ago)335xi- JB4 G5 iso/e50 custom flash/Custom meth/Borla mids/Custom x-pipe/DCI/ER charge pipe/Dual Ebay BOV's/Alpina B3 flash/Paddle shifter retro fit
06-15-2013, 04:40 AM | #6 |
Rep 7,377
Isnt that plate important for rear sosp?
06-15-2013, 07:01 AM | #7 |
Rep 5,463
I have a much smaller one on my 08, but either way I would fix the problem properly and not just remove something that obviously has a purpose for being there! If it is just that the exhaust can't be made to fit without hitting, I would heat wrap the area or something to stop the rattle before I removed something.
2025 X5 Msport
06-15-2013, 08:01 AM | #9 | |
Rep 2,590
06-15-2013, 08:30 AM | #10 | |
Rep 719
