Issues: Shaking at idle, white smoke at idle and acceleration, violent shaking
06-16-2013, 11:32 PM | #1 |
Rep 803
Hey guys
Recently, about a couple months ago, I noticed my car having rough starts. Felt like the power was there, but the car would start jerking (like hiccups) even while reversing for about a minute or two. After a minute of driving it seems to stop. I didn't think much of the situation until a couple weeks ago when I noticed a little bit of smoke coming out of my tailpipes even before the car fully warmed up. The smoke has worsened and I can see it at night in my rearview when I give it gas if there is a car behind me with their lights shining. And most recently, I left my car idling for 15 minutes and it started shaking violently and a "service engine soon" light came on, almost felt like it was spitting or cutting out power every couple seconds. As soon as I went to drive it continued jerking for 5 minutes. I had tried turning it on and off. What could the problem be? I had sparkplugs, oil, and basic maintenance completed only a few thousand miles ago. Edit: Extra details- Mods- Vishnu tune on map 1 and muffler delete, that is all No codes except for the time my car idled for 15 min
black/black/black e92 loaded
Instagram: _eamon_ Last edited by eamon; 06-17-2013 at 12:37 AM.. |
06-17-2013, 09:41 AM | #2 |
Rep 911
Shaking -> Either a dying HPFP or injectors/plugs/coils
Fumes -> Turbo's might be leaking but could also be caused by gasket issues around your engine. As you have fumes during acceleration the chance is there that is caused by your turbo's. What kind of oil do you use? I have had issues in the past by using BMW certified but too thin oil (0w30 and 0w40) and after using 5w40 again my smoke issues went away. Also check if you have either white-is or black fumes and if you have oil residu around/in your exhaust tips. half burned oil = white-is burned = black BUT if "pure" black oil is dripping of your exhaust this could indicate that oil is leaking after your cylinders -> Possible turbo seals. Anyway, dealer/mechanic time.... but check your oil type!
BMW 335 E92 09 - Full options - DKG - MHD by Buraq - RB Next Gen - RB Inlets/Outlet - Forge Diverter Valves - AR Catless DP - Afe Intake - Helix IC - FuelIT Stage 2 LPFP - Ar Oil Cooler - PPK Water Cooler - M3 Suspension - JRZ RS1 Shocks - Eibach Pro Springs - Drexler LSD - BMW IS Exhaust - Carbon Endurance Brake Pads - Stainless Steel Brake Lines - M101 Wheels - Michelin PS2 - M-Tech Body - M-Strutbar
BMW M550i G30 2019 - BM3 |
06-17-2013, 10:39 AM | #3 |
3442
Rep 79,211
If you throw a Service engine soon light or any CEL you have codes. Not all generic scanners or code readers can read them though.
We are all just guessing but it sounds fuel related. Injectors, HPFP or LPFP. |
06-17-2013, 02:24 PM | #4 | |
Rep 803
What do you mean by white"-is?" I can't tell if the fumes are white or greyish but the exhaust tips are completely black inside and pretty dirty on the outside. I also noticed a very slight clicking or tapping sound coming from around the car, not sure if its relevant. |
06-17-2013, 02:25 PM | #5 | |
Rep 803
I also had my hpfp replaced just a few thousand miles ago after getting long cranks, I think. |
06-17-2013, 10:01 PM | #6 |
Rep 719
Its infector(s) probably.... Scan it
ASE master tech (many moons ago)335xi- JB4 G5 iso/e50 custom flash/Custom meth/Borla mids/Custom x-pipe/DCI/ER charge pipe/Dual Ebay BOV's/Alpina B3 flash/Paddle shifter retro fit
06-18-2013, 06:08 AM | #7 |
Rep 911
Procede will not clear engine issues, only tuner codes.
06-19-2013, 08:15 PM | #9 |
Rep 911
answers are given: Injectors, plugs,coils, but in case you have already replaced the HPFP, could be your injectors..
Have you inspected your plugs?
06-19-2013, 09:29 PM | #10 | |
Rep 803
Plugs were replaced 2k miles ago. I was kind of wondering if it would be a full turbo replacement or just the seals. The only thing that worried me was when a tech I ran into told me it could be the seals for the cylinders which would be considered as a head job and take 20+ hours to fix. Going to take it in the next couple weeks.
Instagram: _eamon_ |
