E90Post
Coby Wheel
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Thermostat oil leak
Reply
      06-21-2013, 10:20 AM   #1
Chrisred
Chrisred's Avatar
Drives: BMW 335xi coupe
Have oil leak on top side of thermostat. Seems to be coming from where the thermostat is joined by its two pieces. Right in the middle when looking at it from above. And leak doesn't seem to be coming from where the oil filter is. Any suggestions? Is this a big job?? $$$$???
JB4 Trebila tuned cp-e IC AMS exhaust BMS DCI AR DP's METH RB TURBO
19" VMR VB3 Stoptech BBK TC KLINE VORSHLAG SPEC STG 3 OSS design
      06-21-2013, 10:23 AM   #2
Rotorocious
Rotorocious's Avatar
103
Drives: 335xi
Not a huge deal.
If you haven't had the oil tstat housing gasket done yet do both at the same time.
There is a DIY for it in that section
      06-21-2013, 10:24 AM   #3
enrita
enrita's Avatar
Sweden
161
Drives: 335i - Big turbos
Common issue many threads about it
      06-21-2013, 12:35 PM   #4
Chrisred
Chrisred's Avatar
Is it the oil filter housing seal 11427525335
Or oil filter housing gasket 11427537293
Cause seems from where it's leaking (middle of thermostat) its the seal, as the oil filter gasket is on the left closer to engine.
      06-21-2013, 01:37 PM   #5
Chrisred
Chrisred's Avatar
its either #15 (oil filter housing gasket) or #16 (oil filter housin seal) or both.
its not leaking from #18
also this is what the leak looks like
      06-21-2013, 01:38 PM   #6
Rotorocious
103
Drives: 335xi
Originally Posted by Chrisred View Post
Is it the oil filter housing seal11427525335
11427537293 - #4
11427525335- #5
Replace both of them. They are both prone to failing.
Quite odd to have oil there, though. You sure someone didn't spill oil while changing that filter? Maybe check the oring on that as well at the same time.
      06-21-2013, 01:40 PM   #7
Chrisred
Chrisred's Avatar
Originally Posted by Rotorocious View Post
11427537293 - #4
11427525335- #5
I'll check it out but doubt it as oil doesnt seem to come from the oil filter housing. And also keeps reappearing once I wipe it....so no oil spill
Reply
e90post
