06-21-2013, 06:54 PM | #1 |
pullin a boat
37
Rep 479
BT Audio coding on 2014 F31 (NBT Nav)
Hello,
I'm looking at a 2014 F31 with NBT nav that a dealer has in stock. It has all the options I want except for the ConnectedDrive package, which includes BT Streaming, dual phone pairing & Apps. Now I believe there is no change hardware-wise as the NBT has an integrated combox. So there must be a way to code BT Audio & Apps to that car, is there not? Does it require a simple coding change or does it involve buying an activation code? Thanks.
2021 X3 M40i, Phytonic/Cognac Past: 2017 330i xDrive Touring M Sport, EBII, Dinan 2014 328d xDrive Touring M Sport, BSM/CR. |
06-22-2013, 08:00 AM | #2 | |
BimmerPost Supporting Vendor
668
Rep 1,980
Drives: 2020 G20 320i M Sport
The process would be the same as enabling it on a CIC equipped car by simply changing the bluetooth option on your VO from 6NH to 6NH then recoding your HU_NBT module. As for BMW Apps, you will need an FSC code to enable that. |
06-23-2013, 09:57 AM | #3 | ||
pullin a boat
37
Rep 479
06-23-2013, 09:27 PM | #4 |
Rep 41,020
Drives: 2018 Alpina B6 650ix GC
Technically, yes, but a dealer will almost always look at the car VO, see it does not have factory 6NR, and claim they cant order it. You can buy them though from any independent dealer with ASAP Portal access.
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant 2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE |
06-24-2013, 10:11 AM | #5 |
pullin a boat
37
Rep 479
I have a pretty good relationship with my dealer so I don't think that's going to be an issue. What should I ask them?
06-24-2013, 10:52 AM | #6 |
Rep 41,020
Tell them you want to buy a 6NR BMW Apps FSC Code. I don't think you will get far though.
