Do you need to remove the front bumper when installing FMIC?
06-24-2013, 10:08 AM | #1 |
Rep 461
Drives: BMW 330i G20
Hey guys,
Me and a friend are gonna install the 7" VSRF intercooler and I spent some time reading some DIYs about installing intercooler. This DIY http://www.billswebspace.com/335HelixIntercoolerDIY.htm doesn't remove the front bumper but after reading some other DIY they removed the front bumper. Has anyone installed the VSRF FMIC and can say whether it's necessary to remove the bumper? Thanks Last edited by Fedorov; 06-24-2013 at 03:21 PM.. Reason: added info about the size of the FMIC |
06-24-2013, 10:10 AM | #2 | |
Rep 342
Drives: E90 Monaco Blue 335i xdrive
2010 E90 335i xdrive | Monaco Blue with Black Interior | All Packages except Sport :/ | Apex EC-7 | Active Autowerke Strut Bar | Roc Euro DCI | Roc Euro Hyperboost DVs | aFe Scoops | BMW Performance Exhaust | BMWCCA member
06-24-2013, 11:01 AM | #3 |
Rep 913
I think my installer did, but no you do not have to remove the front bumper. If you are installing the 5" it will fit right in. If you are installing the 7", you will have to trim a bit of the shrouding in front of the bumper (between bumper and IC)
06-24-2013, 12:54 PM | #4 | |
Rep 83
I have the 7" intercooler and removal of the bumper made the trimming that was required a lot easier to accomplish. |
06-24-2013, 01:33 PM | #5 |
3442
Rep 79,211
Technically you can install it without the bumper removed but to some it makes installing the FMIC easier, especially when trimming is involved.
06-24-2013, 01:54 PM | #6 |
PWR JNKY
Rep 28
06-24-2013, 02:17 PM | #7 |
Leeeroy Jankins
31
Rep 423
I did not remove the bumper. Ill be installing my friends in a month and will also NOT remove the bumper. The "extra work" needed to trim the 7" version from the bumper without removing is probably a lot less time then what it takes to remove and put a bumper back on. I can't use my ipad right now to show some pics but I have two circles on the areas I trimmed. There is of course the right side not shown in pic that is trimmed the same.
https://www.dropbox.com/s/377epfgm2m6p1k0/Trimmed-Plastic2.jpg I will be removing my front bumper in the next week and will be curious to see how quick a job it is. My advice would be that if you don't have proper cutting tools, to just remove the bumper for ease. Air tools ftw!
e90 LCI w/ -= VRSF 7" FMIC =-
-= Cobb: Stg1 +FMIC Aggressive ST =- Last Install: BMS DCI + Caliper/Drum Paint "If you're not 1st, you're last" -Ricky Bobby |
06-24-2013, 02:48 PM | #8 |
Rep 913
would seem if you have lift, there should be not need to remove the bumper - though it may still be a little easier if you do.
06-24-2013, 02:54 PM | #9 |
Rep 3,732
Drives: BMW S1000XR
+1, if you have the larger FMIC and trimming is involved remove the bumper. It is really simple. My Forge FMIC did not involve trimming and was a direct fit so I installed with the bumper in place. GL
BMWCCA member |
06-24-2013, 03:39 PM | #10 |
Rep 461
Thanks guys! Excellent information.
I ordered the 7" and since I have the BMW Aero Bumper I reckon I might have to take the front off but it would be awesome if I didn't have to... I guess I also get some sort of installation info packaged with the VSRF Intercooler. Too bad that trimming is needed but the things you would do for power.. |
06-24-2013, 03:56 PM | #11 |
Rep 775
The removal of the front clip should realistically only take 30 mins R&R. Saves a lot of hassle when really doing any work underneath there.
14' M235I | BMW Performance Exhaust | BMW Performance Diffuser | BMW Performance Carbon Interior | ER DP |
JB4 S2 | BC Forged HB29's | N54Tuning.com | getBMWparts.com Current: 2015 Cayman S on HRE P101 |
06-24-2013, 04:29 PM | #12 |
Rep 83
06-25-2013, 08:42 AM | #14 |
Rep 380
I have the vrsf 7" and i never removed the bumper. What made it a really easy job was having a lift. This was my first time ever installing a fmic and the whole job from start to finish took me about 2hrs. As far as the trimming goes, i wouldnt even waste your time trying to cut a few inches, and then realizing you have a couple more to go. Just cut the whole piece out and save yourself alot of headache. I used a sawzall
09 tasman 335 6mt cpe, jb4 g5, bms dci, bms 3" catless dp's, 7"vrsf fmic, e85+93
06-26-2013, 09:04 AM | #15 | |
Rep 461
06-26-2013, 09:46 AM | #16 |
Rep 380
ya i just have oem stock front bumper, but if you have a lift i wouldnt even bother taking the bumper off. It was a really easy install!
06-26-2013, 11:33 AM | #17 |
Rep 1,105
I removed it when installing my 7" VRSF. Makes things much easier, bumper comes off in under 10min.
Good time to pop out lower grills and paint them as well. |
07-06-2013, 11:25 AM | #21 |
Rep 461
Ok, now me and my friend installed the new VRSF 7" intercooler and two pieces of advise that will save valuable time:
* Remove the front bumper. Don't even think about trying to fit the intercooler without removing the front bumper. * You need to cut away the plastic behind the front bumper where the intercooler will be positioned. The VRSF 7" is to big to fit if you don't cut this section away (with I had a picture to show but I don't). There was no way in hell the intercooler was gonna fit like at 9:20 in this movie: My friend also made two mounts as used at about 1:30 in this movie...: ...just because we felt it wouldn't harm to secure the intercooler from moving back/forth. Maybe such mounts should be included in when buying this intercooler. It would have been awesome if there had come some sort of installation instructions with the package but we managed decently with the videos linked previously in this post. No doubt you need to have access to the proper tools when doing this. There is no chance to install this thing just using a screwdriver and wrench |
07-06-2013, 11:29 AM | #22 |
Jedi samurai ninja turtle
621
Rep 3,021
Drives: X3 M40i 2018
Depends on your bumper and IC combo. Msport with Helix did not need to be removed.
