E90Post
The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Stage 1 sport COBB
Reply
      06-27-2013, 08:59 AM   #1
tennis_pr0
Drives: 2--7 BMW 335i coupe
Stage 1 sport COBB
I will be rubbing cobb stage 1 sport on my stock 335. I always use 93 octane, but for this stage it calls for 91. Is it ok if ibuse 93 for this stage?
      06-27-2013, 09:02 AM   #2
KMEninety335
KMEninety335's Avatar
Drives: E90 Monaco Blue 335i xdrive
always fine if you use something better. You can run sport or aggressive with 93. Just data log it to make sure everything is running silky smooth.
2010 E90 335i xdrive | Monaco Blue with Black Interior | All Packages except Sport :/ | Apex EC-7 | Active Autowerke Strut Bar | Roc Euro DCI | Roc Euro Hyperboost DVs | aFe Scoops | BMW Performance Exhaust | BMWCCA member
      06-27-2013, 09:06 AM   #3
eric@helix
eric@helix's Avatar
Drives: 01 M Coupe, 08 135i, '12 328i
^This^
      06-27-2013, 09:09 AM   #4
JAL0988
JAL0988's Avatar
125
Drives: 2023 X7 40i, 2022 X5 M50i
Run aggressive if you have access to 93 and have fun
      06-27-2013, 09:44 AM   #5
JStang
JStang's Avatar
563
Drives: FDB M3 CS
Start with the Drive map on 91 octane and log. If there are no timing corrections jump up to the Sport Map. If that map looks happy go to aggressive. This would be a cautious approach.
Have you changed your spark plugs recently?
      06-27-2013, 10:11 AM   #6
FCobra94
Guest
n/a
Drives:
^ this. Pretty much common sense to start slow and work your way up after logging.
      06-27-2013, 10:34 AM   #7
tennis_pr0
All my spark plugs were changed 4k miles ago..
      06-27-2013, 10:39 AM   #8
tennis_pr0
How much of a difference is there between regular stage 1 and aggressive?
      06-27-2013, 10:42 AM   #9
E90Company
E90Company's Avatar
Drives: Car
There is no regular. There are Drive, Sport, and Agressive maps. If you have 93 octane run stage 1 Sport, log, if all is good then go to Agressive. I use ATR to fine tune my maps, but if you arn't willing to do so contact a protuner.
      06-27-2013, 11:26 AM   #10
sickem
Freude am fahren
sickem's Avatar
71
Drives: E90 N54
I already told him this in one of the eleven threads he's started in the last 36 hours. I'm by no means an expert on this stuff but I do know how to
Cobb E40 PROtune by Jake@PTF/RR catless DPs/aFe DCI/ETS 5" FMIC/ER CP/Forge DVs/Alpina B3 TCU flash/BMW Perf. Exhaust./BMW Performance Style 313s/M-Tech Rear
      06-27-2013, 11:51 AM   #11
srcstc
Drives: 2016 Camaro 2SS
They mean 91 as a minimum. More is better.
      06-27-2013, 12:06 PM   #12
Torgus
Slow.
Torgus's Avatar
Drives: Single Turbo N54 on Meth!
2007 BMW E92  [10.00]
2007 BMW E90  [0.00]
2006 BMW E91  [0.00]
Hmm I never bothered logging on stage 1 aggressive. Would the car bog or would I notice anything if it wasn't running right/smoothly? Doesn't the car automatically protect itself?
I guess I should figure out how to log with my cobb...
      06-27-2013, 12:22 PM   #13
Maxspeed
Drives: 2009 BMW 335i Coupe
Higher octane is usually a good thing. Low octane could result in knocking. Also, make sure you have either a drop-in filter, or dual cone intake. The extra flow over stock makes the car happy.
+1 on what the other guys said. You are definitely better of starting with the drive map and logging, and then going to sport, then aggressive if everything looks good in the logs. Have fun!
      06-27-2013, 02:37 PM   #14
Ænema
If your car/fuel isn't liking the tune then it will more than likely cause a couple issues. Throttle closure caused by overboosting or excessive timing corrections. Both of which can be felt while driving if severe enough. Throttle closures can feel like a "bucking" sensation when the throttle plate slams shut and timing corrections will cause the car to fell less powerful. However, datalogging is the only way to be sure if there is a problem or not.
As far as the OP is concerned, I actually disagree with the consensus a little bit. I recommend just loading the map appropriate for your fuel(aggressive for 93) and let it adapt for a day or so and then grab a couple datalogs. The OTS maps are pretty conservative and there is no risk of engine damage in this scenario. If it is a little too much then flash over to sport and log.
"I'm not surprised you get along well with all the other neighbours. If you put fifty children with Down's syndrome in a room there is going to be a lot of hugging." David Thorne
      06-27-2013, 02:52 PM   #15
douwe22
dual Afe intake/ cobb/ forge dv's/ 94 oct.
douwe22's Avatar
Drives: 2008 bmw 335xi, 2008 x5 4.8i
      06-28-2013, 08:30 AM   #16
tennis_pr0
At VAC now and getting the cobb installed and also getting a drop in air filter. Very excited! Steve at VAC recommended fusing stage 1 sport for nice daily driving smooth power. I will post back after my first drive
      06-28-2013, 08:35 AM   #17
Torgus
Slow.
Torgus's Avatar
2007 BMW E90  [0.00]
2006 BMW E91  [0.00]
Good to know. Thanks man. I guess I will datalog anyways, have to learn sometime.
      06-28-2013, 08:40 AM   #18
JStang
JStang's Avatar
563
Drives: FDB M3 CS
You are paying someone to install the tune and put in a filter?
      06-28-2013, 08:43 AM   #19
tennis_pr0
They are doing it for free.
      06-28-2013, 08:43 AM   #20
JStang
JStang's Avatar
563
Drives: FDB M3 CS
Nice. Enjoy the flash.
      06-28-2013, 08:46 AM   #21
tennis_pr0
Thanks. They said its better to have to car hooked up to a machine or something, kind of like a laptop beijg plugged in, while doing the install
      06-28-2013, 09:00 AM   #22
JStang
JStang's Avatar
563
Drives: FDB M3 CS
They recommend that you hook up the battery to a charger.
Reply
e90post
