06-28-2013, 03:44 PM | #1 |
Rep 568
Removing failed touchup paint?
So I bought a tube of touchup paint from BMW (mineral grey), and tried to use it on some scuffs from a too tight parking space. Unfortunately, apparently just taking the brush that came with the paint and applying it to the scuff doesn't work, and now I have paint that's more black than grey (I guess too thick?) over that entire area, and it's ugly as hell.
I want to remove the touchup paint without damaging the original paint around it. Would nail polish remover work to just remove the newer paint? (I'm assuming the original clear-coat and the opticoat I got afterwards would protect the original layer of paint). If not, what other options do I have? |
06-28-2013, 05:31 PM | #2 | |
Rep 14
The "blob eliminator" will take it off pretty easily.
07-08-2013, 02:33 AM | #3 |
Rep 110
Did you try other solutions to the scuff marks before you went for the touchup paint? Frequently, minor swipes leave cars with paint transfer which doesn't really hurt the paint that much. It can be fixed with some detailing clay or maybe some polishing. After you get the touchup paint removed, I'd take it to a good detailer and have them try some basic spot paint correction (assuming you haven't done that already).
2016 340i M Sport | 6MT
07-13-2013, 06:30 PM | #4 |
Rep 568
Thanks gtuel the Langka worked great! Got rid of all that ugly splotches. Though the OEM BMW touchup paint stick still blows. Looks more dark grey/black than mineral grey.
07-13-2013, 06:40 PM | #5 | |
Rep 4,553
Did you shake the paint stick well before using? The included brush won't work well to spread metallic colors. You need a tool that will allow you to carefully place a blob of the color and let it naturally flow to cover the damaged area. There's some websites that discuss the process, but its not easy. Solid colors are easier to touch up, unfortunately BMW seems to be getting away from solids....
2023 840GC | 2021 740i | 2019 X3
07-13-2013, 08:50 PM | #6 |
Rep 14
I'm glad it worked for you. I used the Langka products on previous cars, and it does a nice job, but it really depends on the quality of the touch up paint you use. I've since switched to using Dr Colorchip and highly recommend it, especially for darker colors. I've used it on my mineral grey and have been happy with the results.
