Can anybody here make -4AN fittings?
06-29-2013, 06:16 PM | #1 |
DIYER
614
Rep 5,521
I need a custom -4AN fitting made....can anyone here do this? I would have "Devils Own do this but I think there communication is limited by storm damage.
JB4 G5, Stage 3 LPFP, Stage 2 MOTIV PI, VM 6466 ST, Custom OCC W/ SS lines, ER FMIC, ER CP W/HKS BOV, M3 control arms, M3 guide rods, M3 upper links, M3 front & rear sway-bars, HPA rear toe arms, Wavetrac LSD, HPF Gen 2, DEFIV kit, KW clubsport, Delrin solid SF bushings, stoptech rotors, Rogue Tranny Mounts, 1M bumper, M3 CF hood, M3 fenders, M3 OEM sideskirts, Mtech rear bumper, CSL trunk, MORR VS8.2 rims 245/295
06-29-2013, 06:30 PM | #2 |
FSAE Dude
62
Rep 759
you've checked places like summit racing and theres nothing like that premade?
2007 TiAg 328xi: AA Tune, AFE intake, Full exhaust, 335xi Brakes, H&R RSB, UUC FSB, H&R Sports, Billy Sports...BBS SR 17x8
1985 Gazelle Beige 325e: Poly everything, e24 3.25 LSD, 225 lb weight reduction, Corbeau FX1, Shifter machined by me, roll bar, harness, all the other goodies. My "Racecar"...15x7 BBS RA |
06-29-2013, 08:16 PM | #5 |
DIYER
614
Rep 5,521
the flex section I want gone...I just want the hard piped curved part.
06-29-2013, 08:19 PM | #6 |
DIYER
614
Rep 5,521
I guess, I actually I never looked for it that way...because 90 degree seems like a a sharper bend...but I guess it is not.
06-29-2013, 08:23 PM | #8 |
Rep 7
We can't physical make the line any shorter as it will not fit in the machine we use to crimp the ends.
Not sure but why are you not using our 90 deg nozzle holder? http://www.alcohol-injection.com/en/...le-holder.html Are you needing something taller? Could use use a fitting simlar to the silver fitting that you have a nozzle in that is 1/8nptmale to 1/8npt female then what ever lenght you need if you need more height. |
06-29-2013, 08:27 PM | #9 | |
DIYER
614
Rep 5,521
06-29-2013, 08:27 PM | #10 | |
Rep 1,843
or actually you might be able to find the whole assembly premade, thinking maybe Earl's, Pegasus Racing, Summit, Jeg's, Speedway Motors might have something? If you were local to me there's a chain of hydraulics shops called Colliflower that could probably hook you up too if you don't want to DIY |
06-29-2013, 08:38 PM | #11 |
Rep 7
With anything that is npt, what the nozzle ends are on both sides.
hand thread the nozzle into the nozzle holder. Then turn it 1/2 a turn with a wrench. Then thread the nozzle into your cold air pipe. Till its hand tight. You will need to turn it atleast 1/2 past this to seal it up. with a wrench. You can turn it more past that to get the clocking you need. Its not a big deal to take a npt threaded item and turn it another 1-2 turns more. The silver fitting and the black fitting you have going into each other. You have them already to tight. All npt threads should only thread together about 1/2 way by hand then 1/2-1 turn with a wrench. Remember npt threads should have ptft sealent used. I don't recomend using tape, as it can clog the orface. So use pipe tape. But with the nozzles you should see about 1/2 the threads till. Npt is a tapered thread. It gets 1 deg closer with each thread. British Pipe thread. Will thread all the way together like pictured but they will usually have a o ring on the fittings to get a seal. |
06-29-2013, 08:41 PM | #12 |
Rep 7
You should also look at your fittings going into the pump. you should see about 1/2 of the thread there and they should also have sealent on the threads. Remember the sealeant is not used on the jic side just the npt side. The newer pumps heads are nicer than the older shurflo pumps we all usta use. The newer pumps do handle having the fittings over tightened in them better. The older pumps would shurly be a goner if tightened to max depth.
Reason for the taper is ever time you take it apart and put it back together it should tighten farther down the fitting. Once it goes threw all the threads its considered a used fitting and should be replaced. |
06-29-2013, 08:55 PM | #13 | |
DIYER
614
Rep 5,521
06-29-2013, 08:56 PM | #14 |
DIYER
614
Rep 5,521
06-29-2013, 08:57 PM | #15 | |
DIYER
614
Rep 5,521
06-29-2013, 09:07 PM | #16 |
Rep 1,392
Easy peasey. A tube bender, a flare tool, 2 an4 fittings, and some SS line. Which i think i have all but the fittings atm
Have a single turbo and/or tired of burning up O2 sensors? Ask me about the new ADV O2 sensor retro kits!
335i 2010 e92 M-sport Mods: VM Top mount 6466, Aquamist HSF4 w/custom direct port. VRSF IC + Exhaust 335i 2009 e90 665RWHP VFF900 ST RIP . |
06-29-2013, 09:08 PM | #17 |
Rep 5,367
Look into making your own rob and use the nylon hoses. I hate working with ss lines!
http://www.russellperformance.com/mc...oclassic.shtml http://www.russellperformance.com/mc...nds/main.shtml
You can follow my builds on IG: Tee212 |
06-29-2013, 09:11 PM | #18 |
DIYER
614
Rep 5,521
I have no idea how to use a flare tool LOL!!!
06-29-2013, 09:11 PM | #19 | |
DIYER
614
Rep 5,521
06-29-2013, 09:19 PM | #20 |
Rep 1,392
I could do it for you but in the middle of a ST and clutch install , then I'm off to vacation for a week. So after that if you still need ill do no problem
06-29-2013, 09:50 PM | #21 |
Rep 567
Is this what you are looking for?
http://www.dragparts.com.au/90-Femal...Other+General+
07 335 6MT
06-29-2013, 09:53 PM | #22 |
Rep 7
Thats why we use a 8" line between the solnoid or check vavle as the standard lenght so it's less likely of loosing the joint. Can always just tighten both sides another 1/2 turn so 1 full turn to keep your clocking.
To keep you from buying anything else. Take the silver fitting off the nozzle put our nozzle holder on it and have going up in the picture than take the 90 and attach it. |
