E90Post
Coby Wheel
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > N54 JB4 Engine Malfunction - Codes
Reply
      07-03-2013, 08:20 PM   #1
AceBMW
Drives: 2008 335xi
I'll try to make this as quick an explanation as possible because I'm really hoping for help in figuring out what I've been experiencing.
2008 335xi with 55k miles, FBO, JB4 map 1 & 2, always 93 gas. I'm normally not driving hard but from time to time when I do get a chance to I'll put it into sports drive and go & what I've noticed is that once I reach higher rpm I'll get a "engine malfunction reduced power" light shortly after & have to ride it out while I'm on highway. Once I turn off the car, let it rest for 15mins or so, start it back up, no longer get the engine malfunction.
I decided to look at codes today & got these:
2A7C No description found
3100 Low Boost Mode Enabled - CEL Displayed
Two codes related to catless downpipes (I knew I'd get these since my DPfix is removed)
Can someone make sense of them & point me in the right direction? I'm particularly curious about the low boost mode enabled, did I accidentally turn on a feature in JB4 that I can simply turn off or is this a boost leak reference. I've tried to do some research on the codes but I'm not sure what it all means. I usually go to a knowledgable service advisor who is aware of my mods so I'd like to present to him what I find out here to resolve my issue as soon as possible. I appreciate any assistance from forum members.
      07-04-2013, 03:14 PM   #2
AceBMW
Drives: 2008 335xi
do i need to provide more information?
      07-04-2013, 03:59 PM   #3
enrita
enrita's Avatar
Sweden
161
Drives: 335i - Big turbos
http://www.e90post.com/forums/search...rchid=27642996
http://www.google.se/search?q=2a7c+b...&client=safari
      07-04-2013, 06:44 PM   #4
AceBMW
Drives: 2008 335xi
i saw that but wasnt sure if that was all it was, change solenoid(s), is that the only reasoning?
      07-04-2013, 06:53 PM   #5
007_e350
007_e350's Avatar
Drives: 335i 2008 MHD'd / x5d E70
I'm not sure, check vaccum lines
Reply
e90post
