switching maps
07-03-2013, 09:36 PM | #1 |
Rep 888
switching maps
Just wondering, but is it okay to switch cobb maps often? I have been switching back and forth to try to find the one I like lately, is this ok to constantly change them like I have been lately or can that confuse or mess up the ECU? I am sticking with the sport map stock throttle but I went back and forth quite a few times already.
07-03-2013, 10:08 PM | #3 |
Rep 888
I was switching maps and realized I downloaded the aggressive map by accident. So after I did that I just restarted the whole tuning process again and downloaded the sport one. I didn't do any damage or confuse the ECU or anything by downloading one and then immediately downloading another did I?
07-03-2013, 10:12 PM | #4 | |
Rep 6,136
07-03-2013, 10:38 PM | #7 |
Rep 414
Who is saying that? As long as your not running the + maps an upgraded IC is not required, unless maybe if you live somewhere that has extreme heat.
"And just one question I might ask yah, and it might sound like A disaster, can you make this thing go faster?"
07-03-2013, 11:12 PM | #8 |
Rep 913
07-03-2013, 11:27 PM | #9 |
Rep 6,478
Another +1 for stg1 aggressive assuming that's as far as you want to go mod wise. It is a VERY conservative map in the grand scheme of N54 tuning, assuming you have 93 pump there is absolutely no concerns from a hardware standpoint. Just log and make sure all parts are in good order, and you'll be set. Don't psych yourself out OP.
E88 N54 Alpinweiss/Coral Red/Motiv HTA 3586r Tial .82AR/Other stuff...652WHP
F30 N55 XDrive EBII |
07-04-2013, 07:10 AM | #10 |
Rep 888
Hmm okay I will try the aggressive map and log. Is it a good map for daily driving? Also, when I go into my map menu on my ccessport, I don't see the aggressive map there. I see stage 1, stage 1 drive, and stage 1 sport, but no stage 1 aggressive. I checked and my accessport is up to date.
07-04-2013, 07:30 AM | #11 |
Rep 888
When I plug my accessport to my computer and run the ap manager software, it shows stage 1 aggressive in the list of maps, but when I plug the accessport to my car and look for it, it's not there on my accessport to choose from.
07-04-2013, 08:59 AM | #14 |
Rep 3,625
Dude, you need to make this your home page http://www.e90post.com/forums/showthread.php?t=472813
07-04-2013, 09:16 AM | #15 | |
Rep 1,434
2022 x5 m50i - Dravit grey
2005 evo 8 (current) built 2.3 488/409 mustang dyno Old stable mates - 87 325i, 88 m3, 90 m3, 97 m3 4dr, 04 325xi, 91 gmc Syclone, 08 335xi, and 13 x3 35i msp 2014 x5 50i msport |
07-04-2013, 11:54 AM | #16 |
Rep 414
Yup and Stage 1 aggressive to 1+ aggressive with an upgraded IC is an even bigger difference in power than going from stage 1 sport to stage 1 aggressive.
Enjoy
07-04-2013, 02:04 PM | #17 |
Rep 888
Well it threw me a code and apparently I had a misfire on cylinder 5. I just had all my plugs changed 4j miles ago. Should I just forget about it and see if it happens again or take it in to get serviced?
07-04-2013, 02:43 PM | #18 |
Rep 270
Try swapping #5 coil with another cyl and see if the missfire changes with coil if so buy a new coil and away you go
07-04-2013, 07:00 PM | #19 |
Rep 888
Yeah I am going to try that. The only problem is I am not sure if I have the tools to do it. The misfire only happened once, I went wot a few times and have been driving a bit since and it hasn't happened again. Should I just leave it alone and see if it happens again?
07-04-2013, 10:33 PM | #20 |
Rep 888
I did a datalog and I did it from 3rd gear at 2500 rpm and took it to redline at 4th gear. I was only going about 100 though, on the other thread he said 4th gear redline you would be going like 130. Am I missing something?
07-04-2013, 11:23 PM | #21 |
Rep 6,136
Upload the log and we can take a look. You are AT or MT?
07-04-2013, 11:42 PM | #22 |
Rep 6,478
Upload the logs and well look. There's really no need for a 4th gear datalog, 3rd does just fine.
