Whats going on with my car
07-04-2013, 06:57 PM | #1 |
Rep 1,909
Alright guys, the car drives good pulls hard except a few times, here are the symptoms:
1- When Idle is at 750 - 800 (fan off, headlights off) 2- the engine doesnot pull hard atall, when punched throws Engine malfunction half light at around 3k RPM Most frequent after the car's been run , shutoff and restarted (still hot) i.e. after pumping gas etc Othertimes when the idle is at 600, the car runs just fine no codes pulls hard Can anyone point me in some direction here ? Could it be something electrical ?? I'm waiting for JB4 usb tomorrow to read the code |
07-04-2013, 07:25 PM | #3 |
Rep 537
spark plugs, coils, injectors, hpfp...
07-04-2013, 07:48 PM | #4 |
Rep 5,660
The second item you listed, OP, sounds reminiscent of something I experienced, although I wasn't watching the RPMs.
I took it to the dealer and told them about and it turned out to be a pressure seal somewhere in/around the turbo chargers. It only manifested itself when I floored it or exceeded 80 mph. The dealer replaced it free of charge as I was under warranty at the time. It was a $4000 repair if I'd had to pay for it. All the best.
Cheers,
Tony ------------------------------------------------------------------------------------------ '07, e92 335i, Sparkling Graphite, Coral Leather, Aluminum, 6-speed |
07-04-2013, 08:26 PM | #5 | |
Rep 1,909
07-04-2013, 09:00 PM | #6 |
Rep 315
07-04-2013, 09:10 PM | #7 | |
Rep 1,909
http://www.ecstuning.com/BMW-E92-335...994/ES2500994/ |
07-04-2013, 10:45 PM | #8 | |
Rep 5,660
If I have time, I can stop by there and ask them for a copy of the work order on that and I'd be happy to share the info with you, but that's the best I can do. It might be worth your while, and your money, to at least let the dealer diagnose the problem for you, even if you don't want them to perform the work. Then at least you'd be in a position to assess just how you want to proceed. If you are good at fixing things, there's no doubt that parts can be purchased, even if only from a BMW dealer. I assume by your reply that you are out of warranty???
Cheers,
07-04-2013, 10:46 PM | #9 |
Rep 5,660
Well, for the OP's sake, I do hope you are merely saying that in jest and seeking a bit of mean humor at the expense of the OP's sanity. I honestly have no idea what a blown piston would sound like.
Cheers,
07-05-2013, 12:11 AM | #10 | |
Rep 315
It's not a happy noise. Last edited by 135Hoser; 07-05-2013 at 12:23 AM.. |
07-05-2013, 09:11 AM | #11 | |
Rep 1,909
07-05-2013, 03:40 PM | #13 |
Rep 315
07-06-2013, 11:36 PM | #14 | |
Rep 1,909
2F84 No Description Found 2F81 No Description Found 2F9E Thermic oil level sensor |
07-07-2013, 02:32 AM | #15 |
Rep 275
Drives: 2006 BMW 330i
^ Seems like you got a boost leak LOL
07-07-2013, 09:42 AM | #16 |
Rep 1,909
diverter valve was leaking really bad, cleaned oil deposits on the connector, couldnt believe it wasn't closing all the way thru because of hard oil gunk ... anyway it doesnt leak now
I used this DIY http://www.n54tech.com/forums/showthread.php?t=13114 Also, took out intercooler cleaned, rinsed and checked hoses, all looks good btw, there was some water left in the intercooler after rinsing lol ... when I started the car this smoke of steam from exhaust filled the whole garage ... scared the **** out of me I'm still max boosting 14 though ... maybe that diverter again, I need to order a new one |
